X-dosBox_0.73_rev_1_test_1 |
pir |
Utente registrato #2110 Registrato il: gio 01 feb 2007 - 20:42Provenienza: France Messaggi: 14 | Please find hereafter the X-launcher for dosBox. First TEST Version (1.856.727 Byte/1,8 Mo) X-DOSBox_0.73_rev_1_test_1.zip Some Portalisation notes - dosBox is very simple to portabilize thanks to its command line that allow to choose its config file location - I usually hav ein my DOSBos config file a set of instructions to automatically mount the directory containing my dos binaries (usually to G: like "games"). I have therefore add to the X-DOSBox.ini file a set of instruction to adapt this part of DOSbox config files to adapt to the real USB drive letter. For that purpose I have supposed that the dos binaries are in $Bin$\DOSBin directory. Up to you to adjust this part of the ini. Have fun [ Modificato lun 21 feb 2011 - 21:54 ] | ||
