Launcher "Local Appdatadir"? |
gibdemaffen |
Utente registrato #38871 Registrato il: ven 04 giu 2010 - 10:31Messaggi: 27 | hi guys, in the launcher ini files, the AppDataDir is adressed as @AppDataDir@. But how can I address "local settings application data" - I tried @localappdatadir@ but this doesn't work out. Thanks for your help | ||
Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 | Hi gibdemaffen, to reach the address "\Documents and Settings\USER\Local Settings\Application Data" the right variable is $LocalAppData$. Is not written with "@" because is not a general AutoIt3 variable, but it is created from the launcher itself. Same stuff for the address "Documents and Settings\USER\Local Settings", where you can use the variable $LocalSettings$. Cheers | ||
gibdemaffen |
Utente registrato #38871 Registrato il: ven 04 giu 2010 - 10:31Messaggi: 27 | Great thanks. Knowing that, I would like to suggest that you enhance your Chromium version with the following: [RunAfter] FileDelete=%Profile%\Default\Cache\*.* DirRemove=$LocalAppData$\Google DirRemove=@AppDataDir@\Adobe DirRemove=@AppDataDir@\Macromedia Chromium leaves various folders behind on the host machine (among them all the Flash stuff). If you add the above lines everything gets cleaned on exit. | ||
