Portable flashplayer for X-Chromium |
JackL |
Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Hi there! the newest version of chromium 6.0.426.0 (49004) -Link- works without problem with x-launcher. news for this version is the support for WebM - new HTML5 video codec with V8 and vorbis audio codec inside. for some reason I could not activate build in flash player - the solution for that is : find flashplayer.xpi downlowed and change extention to .zip extract flashplayer.xpt and NPSWF32.dll create folder "plugins" in \X-Chromium_6.0.397.0_build46552_rev10\Bin\Chrome and copy extracted files there and you can enjoy with portable browser with portable flashplayer now :] Ciao a tutti J | ||
Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3357 | Hi JackL, many thanks for your suggestion. It's very useful!! I tried it and works properly also on my X-Chromium updated on release suggested by you. PS: Same behaviour also on last version of X-Iron | ||
JackL |
Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Hi Guys! I found the parameter that have to be executed with exe shortcut for chromium to enable build-in flashplayer, but... I do not know how to set multiple parameters in launcher (I know - it's lame) can you suggest anything? the tutorial is: "to use the bundled Flash Player plug-in, add --enable-internal-flash to your command line or shortcut for starting Google Chrome" Ciao a Tutti J | ||
JackL |
Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Hi there! I tried hard add new parameters but with no success to - anyone can help? but I have found additional useful parameters instead: --enable-sync-extensions --sync-url = -Link- will enable syncing extensions with your google account all the best J | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Since you have already solved the portable flashplayer problem (see the first post -Link- ), I did not understand why you want to add these parameters in the launcher. However, you can insert them in the same line, in the Parameters field:
Parameters=--user-data-dir="%Profile%" --enable-internal-flash
--- edit --- I found this. So, it seems no more necessary to include NPSWF32.dll in "X-Chromium_6.0.397.0_build46552_rev10\Bin\Chrome\plugins". But a test is needed. [ Modificato dom 20 giu 2010 - 12:58 ] | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | The parameter doesn't work (at least for me). Maybe it works only in Chrome, and not in Chromium. include NPSWF32.dll in "X-Chromium_6.0.397.0_build46552_rev10\Bin\Chrome\plugins". Instead, it works. | ||
JackL |
Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Thanks Danix So that could be a reason why it didn't work for me as well (I have tried several options to include multiple parameters) ok - I will follow that and in case I would find something interesting, I'll let you know KR J | ||
gibdemaffen |
Utente registrato #38871 Registrato il: ven 04 giu 2010 - 10:31Messaggi: 27 | Chromium hasn't got built in flash - instead you could download a version of Chrome (in this case 437.3) - just go to -Link- download the package, open it using 7-zip, and extract the content. Works with the Chromium launcher. edit: you should enhance the launcher .ini with the following lines, in order to remove stuff Flash leaves behind on the HD.
[RunAfter]
[ Modificato lun 21 giu 2010 - 10:47 ] | ||
JackL |
Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Hi Gibdemaffen, DirRemove=$LocalAppData$\Google is not a good idea if you have any other googles products e.g picasa - I had to scan and tagg again all my collection | ||
