can't remove "portable file assosiation" |
JCL |
Utente registrato #39110 Registrato il: sab 10 lug 2010 - 12:54Provenienza: Vienna, Austria Messaggi: 20 | when using win7 and the "exit" command in winPenPack the winPenPack will close down - not so the "portable file assosiation" the icon will not show any menu - does'nt matter left or right mouse-click any hints ? | ||
JCL |
Utente registrato #39110 Registrato il: sab 10 lug 2010 - 12:54Provenienza: Vienna, Austria Messaggi: 20 | hello again, the problem is solved ... under win7 ... as long as the program is in the shielded-area of the toolbar you will not be able to get a response from any mouse-click so ... drag the "portable file assosiation" icon to the visible part of the toolbar and the program can be removed ( all the other options are visible too ) hope someone can use it too | ||
Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3358 | Hi JCL, many thanks for Your feedback. Maybe it can be useful for other users. [ Modificato lun 12 lug 2010 - 11:00 ] | ||
