go4unkwn |
![]() ![]() Utente registrato #39221 Registrato il: dom 05 set 2010 - 09:49Messaggi: 5 | hello I try to use your winPenPack launcher under wine in a Snow Leopard x11 environment. The winPenPack launcher runs fine. I can modify language settings an other options, but when I try a right-click in order to install a X-Software Package the window to choose the X-Software won't open. Does the winPenPack launcher use some windows system internals when it installs X-Software on a USB Stick. You publish the source code of the winPenPack Launcher. Does it help to study the source code to isolate my problem. When yes, please, could you tell me, which development environment I have to use in order to study the source code. Kind regards, go4unkwn | ||
![]() ![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | Hi go4unkwn, you can find the source code of the winPenPack launcher (the "Menu") and the X-Launcher (the portable "engine") in the download section, have a look there... Best regards | ||
