UweKeim |
![]() ![]() Utente registrato #39388 Registrato il: mer 08 dic 2010 - 15:40Messaggi: 2 | Software name: Zeta Uploader Direct Link to download: www.zeta-uploader.com/zul.exe File size: 1.5 MB Author name: Uwe Keim Author website: www.zeta-uploader.com Description: Application to send multiple files or folders to e-mail receivers by uploading them to the internet and sending an e-mail link. Version: 2.1.0.22 Dependencies: .NET Framework 2.0 or higher License: Freeware Screenshot: Longer Description: Zeta Uploader is a tool that enables you to send one or multiple files or folders to one or multiple e-mail receivers. This is done by selecting the files locally on your computer and then automatically upload them to the internet. The receiver get notified by e-mail when a file was uploaded for him. Clicking the link in the e-mail downloads the file. Features include:
Maybe my application can make it into your list of portable applications. It would make me rather proud and happy ![]() Thanks Uwe [ Modificato mer 08 dic 2010 - 17:12 ] | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12926 ![]() | Hello UweKeim, thank you for your signalling. Unfortunately the program is not portable because it stores settings in Windows registry: Spoiler: | ||
UweKeim |
![]() ![]() Utente registrato #39388 Registrato il: mer 08 dic 2010 - 15:40Messaggi: 2 | Thank you Danix. Is there a recommendation from you where to rather store? I will then fix and try to re-submit. Best regards Uwe | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12926 ![]() | UweKeim ha scritto ... Is there a recommendation from you where to rather store? I suggest you to store settings in a .ini file inside the zul.exe directory. | ||
