Link sponsorizzati
Vota per winPenPack su SouceForge!
Vota adesso!
x-Firefox4 rev 1-3 settings problem
JackL
ven 22 apr 2011 - 21:55
Utente registrato #6127
Registrato il: mar 18 set 2007 - 16:36
Hi,
I do not know it this is a problem of the .ini file but maybe yes - Firefox 4 do not remember to open the last tabs. I'm using the speed deal add-on - maybe this cause the issue - but with Firefox 3.x it was not a case.
ciao a tutti
sab 23 apr 2011 - 16:07
Hi JackL,
same issue here. I'm also using Speed Dial.
I'll go deeply checking during this weekend
sab 23 apr 2011 - 18:55
Hi JackL, welcome back
I state that I don't use Speed Dial.
About reopen tabs, I searched into the X-Firefox-4.ini file for such option, but I have not not found any instruction about reopening (or not) the closed tabs.
I have then tried your test with X-Firefox-4 (without Speed Dial) and it correctly reopens all tabs, so I think that your problem could be caused by an incompatibility between Speed Dial and Firefox-4 (or, maybe, some other add-ons).
But, of course, for completely exclude any portabilization error, you could try the same test with an installed copy of Firefox4 and see if the problem persists.
Best Regards (and happy Easter! )
JackL
dom 24 apr 2011 - 12:55
Ciao Ragazzi!,
I have found the issue :]
Firefox did not remember the last tabs because I set up privacy settings to not keep history....
happy easter!
mar 26 apr 2011 - 09:00
JackL ha scritto ...
Ciao Ragazzi!,
happy easter!
me too! same setting!!
