x-Firefox4 rev 1-3 settings problem |
| JackL |
![]() ![]() Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Hi, I do not know it this is a problem of the .ini file but maybe yes - Firefox 4 do not remember to open the last tabs. I'm using the speed deal add-on - maybe this cause the issue - but with Firefox 3.x it was not a case. ciao a tutti | ||
| Taf |
![]() ![]() ![]() ![]() Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 2771 ![]() | Hi JackL, same issue here. I'm also using Speed Dial. I'll go deeply checking during this weekend | ||
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3819 ![]() | Hi JackL, welcome back I state that I don't use Speed Dial. About reopen tabs, I searched into the X-Firefox-4.ini file for such option, but I have not not found any instruction about reopening (or not) the closed tabs. I have then tried your test with X-Firefox-4 (without Speed Dial) and it correctly reopens all tabs, so I think that your problem could be caused by an incompatibility between Speed Dial and Firefox-4 (or, maybe, some other add-ons). But, of course, for completely exclude any portabilization error, you could try the same test with an installed copy of Firefox4 and see if the problem persists. Best Regards (and happy Easter! )ZioZione | ||
| JackL |
![]() ![]() Utente registrato #6127 Registrato il: mar 18 set 2007 - 16:36Messaggi: 68 | Ciao Ragazzi!, I have found the issue :] Firefox did not remember the last tabs because I set up privacy settings to not keep history.... happy easter! | ||
| Taf |
![]() ![]() ![]() ![]() Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 2771 ![]() | JackL ha scritto ... Ciao Ragazzi!, I have found the issue :] Firefox did not remember the last tabs because I set up privacy settings to not keep history.... happy easter! me too! same setting!! ![]() | ||
