Change default download location permanently |
goyanes |
Utente registrato #27103 Registrato il: mar 19 mag 2009 - 23:08Messaggi: 10 | Hi there. If I mark Desktop in Save files to, after I close firefox, wen I open it again, the default download location is always /winpenpack/downloads. I know that this can be changed in x-Firefox.ini but I tried many options and never got it. Can someone help me? Regards, goyanes | ||
Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12956 | Welcome to winPenPack, goyanes! Are you using the latest version with [rev4] revision? | ||
goyanes |
Utente registrato #27103 Registrato il: mar 19 mag 2009 - 23:08Messaggi: 10 | Danix ha scritto ... Welcome to winPenPack, goyanes! Are you using the latest version with [rev4] revision? Thanks Yes. Just updated Goyanes | ||
[ Modificato mer 13 lug 2011 - 23:15 ] | ||
goyanes |
Utente registrato #27103 Registrato il: mar 19 mag 2009 - 23:08Messaggi: 10 | Thanks. Forgotten to put Dir in front of Desktop. Many thanks. Goyanes | ||
