Firefox 6.0 incompatible with JRE 6 Update 26 |
dropper |
Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | I've found that currently Firefox 6.0 is incompatible with JRE 6 Update 26. On the other hand, Firefox 6.0 is indeed compatible with Java SE 7, but Java SE 7 is not yet available on java.com. In fact, I've found that with Java SE 7.0 occur currently some issues, because it's impossible to use websites with Java applets. Is it not far more useful, that the download of Firefox 6.0 will offered earliest with the completion of Java SE 7.0 for end users? [ Modificato mer 17 ago 2011 - 17:01 ] | ||
dropper |
Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | Meanwhile, I have found the cause of my problem. I have installed a VirtualBox by Oracle on my PC. In it, I've created a virtual machine with installed OS Windows XP Home SP3. In this VM I have installed Firefox 6.0 in conjunction with JRE 6 Update 26. After I have selected the website -Link- , I want to play the game Backgammon. Here will be started a Java applet, but this was not possible. Then I tested the same procedure (Firefox 6.0 + JRE 6 Update 26) on my real PC and it worked flawlessly. Consequently, my virtual machine was the cause of incompatibility between Firefox 6.0 and JRE 6 Update. [ Modificato mer 17 ago 2011 - 23:33 ] | ||
Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3357 | Hi dropper, many thanks for your info/feedback! I've tried and tried to replicate your issue but i was not able to do it! now every thing's clear | ||
