Problem with applying partial updates Vai a pagina << |
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Hi gibdemaffen, After reading your message, I tried to update my 11.0 official (built yesterday following the instructions above) with the nightly build, without errors. But I think that your problem is different, so I will wait for the next partial update of the nightly build and will check if is all ok. In the meantime, please, verify that your "application.ini" file is unchanged ([Crash Reporter] | Enabled=1). Best Regards ZioZione | ||
gibdemaffen |
Utente registrato #38871 Registrato il: ven 04 giu 2010 - 10:31Messaggi: 27 | Alright! Good news! This is my current X-firefox.ini that does the trick - full and partial updates run seamlessly.
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Hi gibdemaffen, nice to see that you have resolved! Just remember that, if you will download a future version of X-Firefox, you will need to edit X-Firefox.ini for the Crash Reporter settings (but I don't think that this will be a problem, for you... ), because we will continue to disable it by default. This is due to the fact that the Crash Reporter creates a folder under user %AppData%, and this, from a "portable" point of view, is not good... We will try to fix this behavior, but maintaining also the possibility to apply partial updates, so stay tuned! Best Regards ZioZione | ||
gibdemaffen |
Utente registrato #38871 Registrato il: ven 04 giu 2010 - 10:31Messaggi: 27 | Hey Zio, I figured out these switches get rid of all stuff Firefox leaves in %AppData%:
[RunAfter]
Vai a pagina <<
