Clam Sentinel - real-time malware scanner |
| dito |
![]() ![]() Utente registrato #11533 Registrato il: sab 31 mag 2008 - 09:32Messaggi: 200 | Nome del software: Clam Sentinel Direct Link al download: -Link- (ZIP without installer)Dimensione File: 1 MB (uncompressed) Nome autore: Andrea Russo Sito Web Autore: -Link- ![]() Descrizione: (from authors site) Clam sentinel is a program that detects file system changes and automatically scans the files added or modified using ClamWin. Require the installation of ClamWin. For Microsoft Windows 98/98SE/Me/2000/XP/Vista (tested) and Windows 7. Clam Sentinel è una applicazione che rileva tutte le modifiche al filesystem e scansiona i file modificati o aggiunti utilizzando l'antivirus gratuito ClamWin (richiede l'installazione di questo antivirus). Il programma rileva anche i dischi rimovibili che vengono aggiunti (ad esempio penne usb) e controlla queste unità fino a quando il programma è in esecuzione sulla macchina o fino a quando la periferica non viene rimossa. Portable tips how-to: not tested, but the download files does not require installation Versione: Clam Sentinel 1.19 Licenza: GPL Screenshot: -Link- ![]() Link Portable Freeware: -Link- ![]() Comment: (from: -Link- )For Clam Sentinel to work consistently on different computers from a portable drive with different drive letters I found it necessary to edit ClamWin Portable's ClamWin.conf file located in App > DefaultData > settings. Here's what I did (the ClamWinPortable directory is at the root of my portable drive and quotes are for clarification only): REPLACE "clamscan = clamscan.exe" WITH "clamscan = ..\..\..\..\ClamWinPortable\App\clamwin\bin\clamscan.exe" REPLACE "quarantinedir = ..\..\..\Data\quarantine" WITH "quarantinedir = \ClamWinPortable\Data\quarantine" REPLACE "database = ..\..\..\Data\db" WITH "database = \ClamWinPortable\Data\db" Also: COMMENT OUT from ClamWin.conf "logfile = ..\..\..\Data\log\ClamScanLog.txt" and in the ClamSentinel.ini file ADD "PathLog=\ClamWinPortable\Data\log" Valutate se può essere interessante. Grazie [ Modificato dom 06 mag 2012 - 09:20 ] | ||
