Meaning of the settings in the file xnview.ini |
dropper |
Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | On the download page XnView is described the necessity of creation of a xnview.ini file in the program folder before the first run of xnview.exe. The xnview.ini file should contain the following settings: [Cache] SavingMode=1 [Start] ParamsSavingMode=1 SavingMode=1 Can someone explain me the meaning of these settings? | ||
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Hi dropper dropper ha scritto ... On the download page XnView is described the necessity of creation of a xnview.ini file in the program folder before the first run of xnview.exe. The xnview.ini file should contain the following settings: [Cache] SavingMode=1 [Start] ParamsSavingMode=1 SavingMode=1 Can someone explain me the meaning of these settings? SavingMode=1 (both into [Cache] and [Start] section) should disable the cache. This should improve performances when running XnView from USB pendrive. ParamsSavingMode=1 means that XNView saves its settings into XnView folder (versus ParamsSavingMode=0, that saves into user folder, and ParamsSavingMode=2, that saves into Windows folder). All these settings are necessary for allowing XnView to run in a portable manner. If you need additional informations, please refer to XnView forum, as we have done. Hope this helps! Best Regards ZioZione | ||
dropper |
Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | As always many thanks for the thorough answers and the remarks on the use of the XnView forum. At this point I want not forget to mention, that I also participate in other forums. But the quality of the winPenPack forum is with clear distance the highest | ||
Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 | Hi dropper, we do all the best for give always exhaustive answers, and we are happy when this objective is reached... Thank you very much! As always, you are welcome! Best Regards ZioZione | ||
