Extraction of IZArc2Go 4.1.7 impossible
dropper
lun 06 ago 2012 - 14:50
Utente registrato #39636
Registrato il: mar 15 feb 2011 - 23:47
I tried to extract IZArc2Go_Setup.exe with Universal Extractor but without any success. Instead I get an error message. The same problem occurs with the attempt to use 7Zip and Inno Setup Unpacker. I suspect that the file IZarc2Go_Setup.exe is defect. Or has anyone an idea to solve this problem?
lun 06 ago 2012 - 15:46
Hi dropper,
Just downloaded IzArc2Go from official DL link and extracted with X-UniversalExtractor without any problem!
maybe your previously downloaded file is corrupted.
Try to DL it again from here: (This link starts automatically the DL: -Link- )
Let us know if You solve the problem.
[ Modificato lun 06 ago 2012 - 15:47 ]
dropper
lun 06 ago 2012 - 16:03
Once again I tried to extract the file, which you have offered me. By the way I used the X-UniExtract 1.6 [rev3]. But it doesn't work. Please look at the error message No. 1 and error message No. 2. Unfortunately is the content of this error message No. 1 only in german language. But you could send me your extracted file in zip format. Thank you
[ Modificato lun 06 ago 2012 - 16:13 ]
lun 06 ago 2012 - 17:52
OK Dropper,
maybe I understand your issue.
Please, try to replace Your "innounp.exe" present in current X-Uniextract with this one here below attached (it is the previous release)
you can easily rename current "innounp.exe" present in " Yourpath\winpenpack\Bin\UniExtract\bin\"innounp.exe" in --> "innounp.exe.BAK" and unzip© the attached one here below inside same folder.
innounp.zip
I'm pretty sure You will be able to easily extract "IzArc3Go"
as second (LAST) chance, You can use my "already extracted version" of "IzArc3Go"
izarc2go4.1.7.zip
But, please, try also my first suggestion and let us know!
[ Modificato lun 06 ago 2012 - 17:55 ]
dropper
lun 06 ago 2012 - 18:52
Thank you for the advice to substitute the old Inno Setup Unpacker file innounp.exe through the newest version 0.37. Now it's possible to extract the file IZArc2GO_Setup.exe with X-UniExtract 1.6 [rev3].
On this occasion I would like to point out that an update from X-UniExtract 1.6 [rev3] would be useful.
lun 06 ago 2012 - 19:31
Happy to know You solved!
Many Thanks for Your feedback and your suggestion!
I'm pretty sure we will provide the update of X-Uniextract as soon as we can.
Part of our staff is on holiday in this period!
ven 10 ago 2012 - 10:01
Hi dropper,
FYI, now X-uniextract is updated to 1.6.1 -> -Link-
and now, with REV4, works properly also during extraction of IzArc2Go!
have a nice week-end!
