Usage of the X-Launcher 1.5.1 |
dropper |
Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | I've tried to make the program RssOwl portable by using the X-Launcher 1.5.1. Here are my ideas:
Are the above statements correct as far as? If not, please explain me the necessary changes. I would be very thankful if I get further information on this issue. EDIT: I've expanded the above list with the numbers 6 and 7. [ Modificato mar 04 set 2012 - 14:10 ] | ||
Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 | dropper ha scritto ... Are the above statements correct as far as? If not, please explain me the necessary changes. I would be very thankful if I get further information on this issue. More simply, you can substitute the existing X-RSSOwl-2.exe with X-Launcher.exe (after renaming it obviously). In the 1.5.1 release, we do not make changes to structure or ini file, we just improved the code of X-Launcher itself to better manage the update with both java installed and java portable (as you suggest ) | ||
