dlusera |
![]() ![]() Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | I used X-firefox 15.0.1 + proable java. recent I update the java to 7U7 version portable. Copy java u7U to "X-Firefox_15.0.1_rev6\Lib\Java ", I sure that java is ok. I test ON "http://www.java.com/en/download/testjava.jsp" But, i has a problems, the java can't working some "java upload" website. And I known that because X-Firefox 15.0.1 [rev6] missing this java plugin: Java deployment toolkit 7.0.70.11 10.7.2.11 I use back old version java the 'Java deployment toolkit ' Is OK. I don't why X-Firefox 15.0.1 [rev6] + portable Java (jre-7u7) has this bugs. I sure I extract the Java portable is 100% corrent, I test many time. Please Test and Fix Thanks. Hope support Help. Sorry My bad english | ||
![]() ![]() ![]() ![]() Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 ![]() | Hi dlusera, checking on the web seems that your problem is due to the npdeployJava1.dll. You can try to fix editing X-Firefox.ini and making this changes: substitute this part
with this one
then try again after restarting X-Firefox. [ Modificato mer 19 set 2012 - 14:33 ] | ||
dlusera |
![]() ![]() Utente registrato #39104 Registrato il: ven 09 lug 2010 - 12:38Messaggi: 37 | I edit x-firefox.ini fix the 'Java deployment toolkit 7.0.70.11 10.7.2.11' problems. but used java for upload websote still not working. old java version is ok. I don't why new not working, is java bugs ? website bugs ? firefox bugs ? also start on flash 11.3 (11.2 ok), 11.4, some website also has hang problems.(Can't login -Link- ![]() I don't why more portable plugin on x-firefox got many problems on win 7 sp1. i already test 2 computer, I sure that a bugs. but still few month not fix yet. any how .thanks. [ Modificato gio 20 set 2012 - 09:51 ] | ||
