Installation of Java Runtime Environment (JRE) 7 Update 10 impossible
dropper
mer 19 dic 2012 - 02:37
Utente registrato #39636
Registrato il: mar 15 feb 2011 - 23:47
I tried to install the JRE 7 Update 10. After I run X-RssOwl, I got the error message, that it's not possible to install Java. Then I've started X-LibreOffice and it seemed, as if Java was updated. Finally I looked in the installed Plugins into X-Firefox, but there will displayed again the old version JRE 7 Update 9. Consequently is really the update failed.
dropper
mer 19 dic 2012 - 20:12
About the website "Test whether Java is working on my computer" I can now confirm, that I use the actual Java version with X-Firefox (JRE 7 Update 10). Nevertheless in my Addon Manager of X-Firefox will displayed the outdated version JRE 7 Update 9. Kind of odd!!!
gio 20 dic 2012 - 08:27
Thanks for Your feedback, dropper.
we'll try to investigate on this strange behaviour
