winPenPack Launcher 2.8.70.2371 check upgrades |
| eflucas |
![]() ![]() Utente registrato #41602 Registrato il: sab 14 set 2013 - 20:57Provenienza: Rotterdam, The Netherlands Messaggi: 9 | When I start the menu, it is checks for upgrades. I get the following message: "Unreachable or invalid URL download list" When I type "http://www.winpenpack.com/update/update.xml.zip" in my browser I get the "update.xml.zip". So the file is available for me! I put it in the folder: "D:\wpp_full_4.3\update.xml.zip" I replace the path from "http://www.winpenpack.com/update/update.xml.zip" to "D:\wpp_full_4.3\update.xml.zip" Restart the menu and then I get the usual message for upgrades! Now the question: Why is this and how to solve it? This error started a week ago. Thnx in advance | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Option >> Various >> Web Upgrades >> Download List, have you the correct path?
| eflucas |
![]() ![]() Utente registrato #41602 Registrato il: sab 14 set 2013 - 20:57Provenienza: Rotterdam, The Netherlands Messaggi: 9 | Yes I have. It's the same path as yours. eflucas ha scritto ... ... I replace the path from "http://www.winpenpack.com/update/update.xml.zip" ... Danix ha scritto ... ...
| eflucas |
![]() ![]() Utente registrato #41602 Registrato il: sab 14 set 2013 - 20:57Provenienza: Rotterdam, The Netherlands Messaggi: 9 | Apparently it was an update of windows that the proxy settings changed. I changed it and now it worked as before. | ||
