Aggiornamento: X-Calibre
Vai a pagina   <<        >>
ven 10 gen 2014 - 10:27
X-Calibre 1.19.0
Link winPenPack -Link-
Aggiornamento dalla versione 1.18.0 alla 1.19.0
Home: -Link-
Direct link not portable: -Link-
Alternate download site: -Link-
What's new: -Link-
--- edit zandet2 ---
software wpp aggiornato
[ Modificato ven 10 gen 2014 - 23:59 ]
rbon
ven 17 gen 2014 - 16:49
Utente registrato #4134
X-Calibre 1.20.0
Aggiornamento dalla versione 1.19.0 alla 1.20.0
Home: -Link-
What's new: -Link-
[ Modificato mar 21 gen 2014 - 22:38 ]
rbon
ven 24 gen 2014 - 17:14
X-Calibre 1.21.0
Aggiornamento dalla versione 1.20.0 alla 1.21.0
Home: -Link-
What's new: -Link-
rbon
ven 31 gen 2014 - 12:18
X-Calibre 1.22.0
Aggiornamento dalla versione 1.21.0 alla 1.22.0
Home: -Link-
What's new: -Link-
New Features
A new tool to compare ebook files, showing the differences in their underlying text, styles and images side by side
The new compare tool is very useful in combination with the book editor. It allows you to see what changes have been made between checkpoints and what changes were made by automated tools. You can also compare different versions of the same ebook file. How to use each of these features is described below. Screenshots and help for using the new compare tool are at -Link-
Edit book: Add a tool to view the list of checkpoints and compare the current state of the book to the state at the specified checkpoint. To use it click View->Checkpoints
Edit book: Add a tool to compare the book being currently edited with another file. To use it go to File->Compare to other book
... and other changes
rbon
ven 07 feb 2014 - 11:57
X-Calibre 1.23.0
Aggiornamento dalla versione 1.22.0 alla 1.23.0
Home: -Link-
What's new: -Link-
ven 14 feb 2014 - 21:56
X-Calibre 1.24.0
Link winPenPack
Aggiornamento dalla versione 1.23.0 alla 1.24.0
Home: -Link-
What's new: -Link-
ven 21 feb 2014 - 14:43
X-Calibre 1.25.0
Link winPenPack
Aggiornamento dalla versione 1.24.0 alla 1.25.0
Home: -Link-
What's new: -Link-
ven 28 feb 2014 - 14:31
X-Calibre 1.26.0
Link winPenPack
Aggiornamento dalla versione 1.25.0 alla 1.25.0
Home: -Link-
What's new: -Link-
ven 07 mar 2014 - 15:09
X-Calibre 1.27.0
Link winPenPack
Aggiornamento dalla versione 1.26.0 alla 1.27.0
Home: -Link-
What's new: -Link-
ven 14 mar 2014 - 14:38
X-Calibre 1.28.0
Link winPenPack
Aggiornamento dalla versione 1.27.0 alla 1.28.0
Home: -Link-
What's new: -Link-
Vai a pagina   <<        >>
