New version of PhotoFilmStrip |
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | Meanwhile was offered a new version of PhotoFilmStrip (2.0.0-RC1). Would be nice, if the winpenpack website can integrate this new version. [ Modificato sab 03 ott 2015 - 22:58 ] | ||
| Taf |
![]() ![]() ![]() Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3376 ![]() | Hi dropper, official "X" version will be released as soon as we can. Actually we are a bit busy. anyway, you have 2 possibilities: -First- use the natively portable edition of 2.0 RC1, present on official site here is the link for direct DL: -Link- ![]() -second- use the RC1 version inside old X-photofilmstrip package you need only to put the folders present in new 2.0 RC1 version already downloaded into the BIN/photofilmstrip/ foder present in our previous package. anyway, first option is easier and works fine.... ![]() [ Modificato mar 06 ott 2015 - 09:08 ] | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Updated! -Link- P.S. now we update X-Software only on request.. ![]() [ Modificato mar 06 ott 2015 - 11:39 ] | ||
| Taf |
![]() ![]() ![]() Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3376 ![]() | Perfect Danix, good to know! ![]() | ||
| dropper |
![]() ![]() Utente registrato #39636 Registrato il: mar 15 feb 2011 - 23:47Messaggi: 165 | Hi Taf, in your answer you recommend me to use 2 possibilities in the meantime, as long as the new official "X" version will be released (which was now done by Danix). But I think, that your 2. recommendation is a little bit insufficient. Because the portability ought to be re-examined. Because some changes made by the programmer can lead to the result, that the originally given portability is no longer valid. Therefore your recommendation is only true in the case, that the natively portable edition of 2.0.0 RC1, which will provided on official site, indeed is completely portable. | ||
| Taf |
![]() ![]() ![]() Utente registrato #251 Registrato il: lun 22 gen 2007 - 10:12Provenienza: Buttrio (UD) Messaggi: 3376 ![]() | dropper ha scritto ... Hi Taf, SNIPPED But I think, that your 2. recommendation is a little bit insufficient. Because the portability ought to be re-examined. Because some changes made by the programmer can lead to the result, that the originally given portability is no longer valid. Therefore your recommendation is only true in the case, that the natively portable edition of 2.0.0 RC1, which will provided on official site, indeed is completely portable. You are 100% right, dropper! My second suggestion was only a temporary "workaround" to have new release inside OLD launcher, waiting for our official release (now already made!). In fact I also suggest to use FIRST temporary solution... ![]() [ Modificato mer 07 ott 2015 - 08:39 ] | ||
