[Fixed] Hijackthis |
Ketty |
Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | Hijackthis -Link- Motivazione Chiave aggiunta:4 ---------------------------------- HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\HijackThis.exe HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HijackThis HKLM\SOFTWARE\Soeperman Enterprises Ltd. HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis Valore aggiunto:12 [ Modificato ven 13 lug 2007 - 00:34 ] | ||
Ketty |
Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | Se non sbaglio queste chiavi, intendo più che altro le seconde, dovrebbero essere rilevanti per il test: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\HijackThis.exe HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HijackThis HKLM\SOFTWARE\Soeperman Enterprises Ltd. HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis Tra l'altro uninstall non so come mai e valori: Valore aggiunto:21 ---------------------------------- HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\HijackThis.exe\: "C:\TEST\hijackthis\hijackthis.exe" HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\HijackThis.exe\Path: "C:\TEST\hijackthis" HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HijackThis\DisplayName: "HijackThis 1.99.1" HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HijackThis\UninstallString: "C:\TEST\hijackthis\HijackThis.exe /uninstall" HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HijackThis\DisplayIcon: "C:\TEST\hijackthis\HijackThis.exe" HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HijackThis\DisplayVersion: "1.99.1" HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HijackThis\Publisher: "Soeperman Enterprises Ltd." HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\HijackThis\URLInfoAbout: "http://www.spywareinfo.com/~merijn/" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\IgnoreNum: "0" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\AutoSelect: "0" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\Confirm: "1" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\MakeBackup: "1" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\IgnoreSafe: "1" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\LogProcesses: "1" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\ShowIntroFrame: "1" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\DefStartPage: "about:blank" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\DefSearchPage: "http://www.microsoft.com/isapi/redir.dll?prd=ie&ar=iesearch" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\DefSearchAss: "http://ie.search.msn.com/{SUB_RFC1766}/srchasst/srchasst.htm" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\DefSearchCust: "http://ie.search.msn.com/{SUB_RFC1766}/srchasst/srchcust.htm" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\WinHeight: "7995" HKLM\SOFTWARE\Soeperman Enterprises Ltd.\HijackThis\WinWidth: "9000" Questo semplicemente avviando il programma, guardando le opzioni senza avviare una scansione. [ Modificato mar 19 feb 2008 - 01:16 ] | ||
Utente registrato #3184 Registrato il: mar 06 mar 2007 - 11:52Provenienza: Busto Arsizio Messaggi: 3301 | Note sulla licenza di Hijackthis (dalle faq sul sito) : -Link- What is the license agreement for your software? All my software is freeware and may be used by anyone free of charge, unless specified otherwise on my website. You are allowed to use this software as long as it is not altered, reverse-engineered or sold. ---EDIT--- sempre sulle faq, ho trovato questo: What command line parameters does HijackThis accept? The following parameters are accepted: /autolog - automatically perform a scan, save it (requiring user input) and open it /silentautolog - automatically perform a scan and save it to disk as hijackthis.log (HJT 1.99.2 and up) /ihatewhitelists - ignore all internal whitelists in all checks /uninstall - remove all Registry settings from HijackThis Al momento non ho la possibilità di testarne l'efficacia, ma l'ultimo parametro potrebbe servire a rimuovere automaticamente le voci di registro... ciao [ Modificato mar 19 feb 2008 - 11:32 ] | ||
Ketty |
Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | E' proprio così come hai scritto. Grazie per l'aiuto/insegnamento Tra l'altro il tutto è già fattibile direttamente dal programma. E' stata una mia gran bella svista. [ Modificato mar 19 feb 2008 - 16:26 ] | ||
alexcyber |
Utente registrato #5886 Registrato il: gio 30 ago 2007 - 00:24Messaggi: 149 | ciao, Tra l'altro il tutto è già fattibile direttamente dal programma. E' stata una mia gran bella svista. potresti spiegare come hai fatto? grazie | ||
Ketty |
Utente registrato #5089 Registrato il: sab 09 giu 2007 - 02:27Messaggi: 1461 | Una volta che hai aperto e utilizzato il programma, in basso a destra hai una voce da cliccare Config... Entrato in quella schermata scegli Misc Tools e scorri sino alla voce Uninstall Hijackthis & Exit Mi è scappato un doppio post [ Modificato dom 09 mar 2008 - 16:30 ] | ||
