 Utente registrato #194
Registrato il: dom 21 gen 2007 - 22:27 Messaggi: 1371
come impostare in sola lettura le periferiche USB con VBscript e WMI:
'dichiarazione variabili
Const HKEY_LOCAL_MACHINE = &H80000002
'The first is the computer that we are working on.
'A "." means the one we are sitting at. Anything else
'is remote. I recommend using the NetBIOS name without
'the slashes, "\\".
strComputer = "."
'I also have a found_key variable set to false. The
'computer I initially checked this on didn't have the
'key at all, even though it is running XP SP2. This
'caused problems at first since there isn't a function
'to see if a registry sub-key exists. This variable
'is used to let us know whether or not the key even
'exists. You'll see why later.
found_key = false
'These next variables tell our script what root to look
'in, what the sub-key is, and what value name to look
'at to see if we are read-only or not.
'If the strKeyPath doesn't exist then USB devices are
'writeable if they are storage devices.
strKeyRoot = "SYSTEM\CurrentControlSet\Control"
strKeyPath = "System\CurrentControlSet\Control\StorageDevicePolicies"
strValueName = "WriteProtect"
'Crack apertura registro per lettura valore a:
Set oReg=GetObject("winmgmts:{impersonationLevel=impersonate}!\\" & _
strComputer & "\root\default:StdRegProv")
'Numerazione chiavi di registro ed inserimento valori in array
oReg.EnumKey HKEY_LOCAL_MACHINE, strKeyRoot, arrSubKeys
For Each subkey In arrSubKeys
if subkey = "StorageDevicePolicies" then
found_key = true ' chiave trovata
exit for
end if
Next
'se il valore non è settato allora la periferica USB è in modalità scrittura.
if not found_key then
'chiedo se si vuole rendere in modalità sola lettura :
Read_Only = Msgbox ("Rendere la periferica USB protetta da scrittura?", 36, "Read-Only?")
if Read_Only = vbYes then
' se si conferma allora il valore DWORD lo setto a 1.
oReg.CreateKey HKEY_LOCAL_MACHINE,strKeyPath
oReg.SetDWORDValue HKEY_LOCAL_MACHINE,strKeyPath,strValueName,1
end if
else
'altrimenti
oReg.GetDWORDValue HKEY_LOCAL_MACHINE,strKeyPath,strValueName,dwValue
if dwValue = 0 or dwValue = "" then
"Read-Only?")
end if
else
if dwValue = 1 then
Writeable = Msgbox ("USB in sola lettura ,renderla scrivibile ?", 36,
"sprotetta?")
if Writeable = vbYes then
oReg.SetDWORDValue HKEY_LOCAL_MACHINE,strKeyPath,strValueName,0
end if
end if
end if
end if
'Ok
Wscript.Echo "Current StorageDevicePolicies: " & dwValue
'End
salvare il testo in un file con estensione VBS ..ed eseguirlo
ATTENZIONE : script pericoloso
