Modifiche e aggiornamenti software da winPenPack 3.2 Go to page << >> |
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Fix (Launcher+INI only) X-Eraser 5.83 Beta [rev2] -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | EssentialPIM Free Portable 2.1 Link winPenPack Aggiornamento dalla versione 2.02 alla 2.1 Home: -Link- Direct Link: -Link- ------------------------------- segnalato da: sceicco [ Edited Mon 01 Oct 2007 - 20:17 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | X-Miranda 0.7.0 Link winPenPack Aggiornamento dalla versione 0.6.8 alla 0.7.0 Home: -Link- Direct Link: (non portatile) (Windows NT, 2000, XP, Vista only) -Link- Direct Link: (non portatile) (Windows 95, 98, ME) -Link- [ Edited Tue 02 Oct 2007 - 12:52 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Fix X-FoxitReader 2.2 [rev4] -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | Magic Mail Monitor 2.94b17 Edit by Danix Eliminato in quanto nei wPPs è presente la versione X [ Edited Tue 02 Oct 2007 - 22:46 ] | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: X-Magic Mail Monitor 2.94b17 Aggiornamento dalla versione 2.94b16 alla 2.94b17 Home: -Link- Direct Link: -Link- NOTE: Questa distribuzione include l'editor testuale Notepad2 per la visualizzazione delle Mail. | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | PC Wizard 2008.1.80 Win95, 98, 98 SE, Me, NT, 2000, XP, Vista. winPenPack link Aggiornamento dalla versione 2007 1.73 alla 2008.1.80 Home: -Link- Direct Link: not portable -Link- Attenzione: per la portatilità del software fare riferimento a questo -Link- [ Edited Wed 03 Oct 2007 - 00:18 ] | ||
alchimista |
Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 | Update: WinAudit 2.26 Win PE/95/98/Me/NT3.51/NT4/2000/XP/2003/Vista Aggiornamento dalla versione 2.25 alla 2.26 Home: -Link- Direct Link: -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Bug Se questo bug viene confermato -Link- , eliminazione di X-Amsn dal wPP 1Gb | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | MediaCoder 0.6.0.3900 Link winPenPack Aggiornamento dalla versione 0.6.0.3880 alla 0.6.0.3900 Home: -Link- Direct Link: -Link- | ||
