X-FileZilla Launcher [only 3.0.0 version]
Mon 10 Sep 2007 - 00:15
Attenzione: solo per FileZilla 3.0.0
; Ini file [rev9] - Author: Danix (winpenpack@gmail.com) - Date: 09.09.2007
; Only for FileZilla 3.0.0 version
; This X-Software is released under GNU General Public License.
AppName=FileZilla
[FileToRun]
[Environment]
USERPROFILE=$ExeDir$
[Functions]
DirCreate=%USERPROFILE%
FileCopy=$Home$\$AppName$\*.xml|$ExeDir$\|o
; * locale it (rimozione lingue supplementari, da attivare) *
;DirCopy=$ExeDir$\locales\it_IT|$ExeDir$\locales_it\it_IT
;DirRemove=$ExeDir$\locales
;DirMove=$ExeDir$\locales_it|$ExeDir$\locales
[RunAfter]
FileCopy=$ExeDir$\*.xml|$Home$\$AppName$\|o
; * backup *
DirMove=$Backup$\$AppName$\backup_9|$Backup$\$AppName$\backup_10|o
DirMove=$Backup$\$AppName$\backup_8|$Backup$\$AppName$\backup_9|o
DirMove=$Backup$\$AppName$\backup_7|$Backup$\$AppName$\backup_8|o
DirMove=$Backup$\$AppName$\backup_6|$Backup$\$AppName$\backup_7|o
DirMove=$Backup$\$AppName$\backup_5|$Backup$\$AppName$\backup_6|o
DirMove=$Backup$\$AppName$\backup_4|$Backup$\$AppName$\backup_5|o
DirMove=$Backup$\$AppName$\backup_3|$Backup$\$AppName$\backup_4|o
DirMove=$Backup$\$AppName$\backup_2|$Backup$\$AppName$\backup_3|o
DirMove=$Backup$\$AppName$\backup_1|$Backup$\$AppName$\backup_2|o
FileCopy=$ExeDir$\*.xml|$Backup$\$AppName$\backup_1\|o
[Options]
DeleteTemp=true
MultipleIstances=true
ShowSplash=true
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
[ Edited Mon 10 Sep 2007 - 00:19 ]
Mon 10 Sep 2007 - 12:39
Purtroppo il programma non riconosce perfettamente la variabile %USERPROFILE%
Quando si va a caricare un file dal desktop o ad importare un XML, appare un messaggio d'errore:
Credo che parta sempre da %APPDATA% per cercare i percorsi.
La soluzione (anche se indiretta, poichè il profilo non si crea direttamente in $ExeDir$) è questa:
; Ini file [rev10] - Author: Danix (winpenpack@gmail.com) - Date: 11.09.2007
AppName=FileZilla
[FileToRun]
[Functions]
DirMove=@AppDataDir@\$AppName$|@AppDataDir@\$AppName$_backup
DirCopy=$Home$\$AppName$|@AppDataDir@\$AppName$|o
; * locale it *
[RunAfter]
DirCopy=@AppDataDir@\$AppName$|$Home$\$AppName$|o
DirRemove=@AppDataDir@\$AppName$
DirMove=@AppDataDir@\$AppName$_backup|@AppDataDir@\$AppName$
; * backup *
FileCopy=$Home$\$AppName$\*.xml|$Backup$\$AppName$\backup_1\|o
[Options]
DeleteTemp=true
ShowSplash=true
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
[ Edited Mon 10 Sep 2007 - 12:41 ]
Wed 12 Sep 2007 - 23:49
In virtù delle seguenti indicazioni presenti in FileZilla\docs\fzdefaults.xml.example,
scoperte leggendo qui -Link- , aggiornato il launcher alla [rev11]
Location of settings directory:
By default, FileZilla stores it's settings in the user's home directory. If
you want to change this location, modify the "Config Location" setting (see
below).
"Config Location" either accepts absolute paths or paths relative to the
location of fzdefaults.xml
You can also use environment variables by preceeding them with the dollar
sign, e.g. "$HOME/foo".
Use $$ to denote a path containing dollar signs, e.g. "c:\$$foobar\" if
settings should be located in "c:\$foobar".
A single dot denotes the directory containing fzdefaults.xml
; Ini file [rev11] - Author: Danix (winpenpack@gmail.com) - Date: 13.09.2007
AppName=FileZilla
[FileToRun]
[Environment]
SettingsDir=$Home$\$AppName$
[Functions]
DirCreate=%SettingsDir%
; * locale it *
[WriteToFile=$ExeDir$\fzdefaults.xml]
Line1=<FileZilla3><Settings><Setting name="Config Location">%SettingsDir%</Setting></Settings></FileZilla3>[RunAfter]
; * backup *
[Options]
DeleteTemp=true
ShowSplash=true
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
[ Edited Thu 13 Sep 2007 - 00:55 ]
Wed 19 Sep 2007 - 23:45
[rev12]
Bug fix: evitata la creazione di una sottocartella (innoqua ma inutile) in Backups\backup_10
Aggiungere alla linea 49:
DirRemove=$Backup$\$AppName$\backup_10\backup_9
Quindi la sezione [RunAfter] diventa:
[RunAfter]
; * backup *
[ Edited Wed 19 Sep 2007 - 23:54 ]
tittoproject
Wed 31 Oct 2007 - 23:31
Registered Member #821
Nella cartella di FileZilla, c'è il file "fzdefaults.xml.example" con istruzioni dettagliate su come modificare la cartella dove salvare le impostazioni:
"FileZilla" wrote ...
By default, FileZilla stores it's settings in the user's home directory. If you want to change this location, modify the "Config Location" setting (see below).
"Config Location" either accepts absolute paths or paths relative to the location of fzdefaults.xml
You can also use environment variables by preceeding them with the dollar sign, e.g. "$HOME/foo".
Use $$ to denote a path containing dollar signs, e.g. "c:\$$foobar\" if settings should be located in "c:\$foobar".
Ecco il codice base per l'X-Launcher:
AppName=FileZilla
[FileToRun]
[Environment]
FILE_ZILLA_HOME=$Home$\$AppName$
[Functions]
DirCopy=$ExeDir$\docs\fzdefaults.xml.example|$ExeDir$\fzdefaults.xml
DirCreate=%FILE_ZILLA_HOME%
[StringReplace=$ExeDir$\fzdefaults.xml]
"Config Location">|</Setting>=$FILE_ZILLA_HOME/
Eh, eh, era da un pò che non usavo questo programma
Wed 31 Oct 2007 - 23:37
tittoproject, mi sa che ti sei perso un passaggio...
tittoproject
Thu 01 Nov 2007 - 00:05
Ah, adesso l'ho visto!
Questo:
Beh, non ho fatto il lavoro per niente: infatti, se usi la notazione $SettingsDir come ho fatto io, eviti di riscrivere ogni volta il file e velocizzi (sensibilmente, si tratta di una linea) l'avvio.
E poi mi sembra più elegante modificare il file di default usando StringReplace.
Thu 01 Nov 2007 - 01:03
S,i in effetti è meglio che far scrivere su un nuovo file.
Lo cambio e integro il backup (sapessi quante volte mi ha salvato! )
Sun 04 Nov 2007 - 02:08
[Functions]
Volevi dire FileCopy, vero?
tittoproject
Sun 04 Nov 2007 - 11:42
[Functions]
Naturalmente
