Aggiornamento: MirandaGo to page << >> |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Miranda 0.8.19 Link winPenPack Aggiornamento dalla versione 0.8.18 alla 0.8.19 Home: -Link- ![]() Direct Link: not portable EXE (Windows NT, 2000, XP, Vista only) -Link- ![]() Direct Link: not portable ZIP (Windows NT, 2000, XP, Vista only) -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Mon 29 Mar 2010 - 14:01 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Miranda 0.8.20 Link winPenPack Aggiornamento dalla versione 0.8.19 alla 0.8.20 Home: -Link- ![]() Direct Link: not portable EXE (Windows NT, 2000, XP, Vista only) -Link- ![]() Direct Link: not portable ZIP (Windows NT, 2000, XP, Vista only) -Link- ![]() ----- edit ----- Rilasci momentaneamente sospesi -Link- ![]() [ Edited Sun 02 May 2010 - 14:53 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Miranda 0.8.21 Link winPenPack Aggiornamento dalla versione 0.8.20 alla 0.8.21 Home: -Link- ![]() Direct Link: not portable EXE (Windows NT, 2000, XP, Vista only) -Link- ![]() Direct Link: not portable ZIP (Windows NT, 2000, XP, Vista only) -Link- ![]() ----- edit ----- Rilasci momentaneamente sospesi -Link- ![]() [ Edited Sun 02 May 2010 - 14:53 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Miranda 0.8.22 Link winPenPack Aggiornamento dalla versione 0.8.21 alla 0.8.22 Home: -Link- ![]() Direct Link: not portable EXE (Windows NT, 2000, XP, Vista only) -Link- ![]() Direct Link: not portable ZIP (Windows NT, 2000, XP, Vista only) -Link- ![]() ----- edit ----- Rilasci momentaneamente sospesi -Link- ![]() [ Edited Sun 02 May 2010 - 14:53 ] | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Proposta: riprendere gli aggiornamenti e conseguenti rilasci di X-Miranda, segnalando nella scheda di download il bug con l'indicazione su come aggirare manualmente il problema (vedi -Link- ). | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Controproposta: dismettere la versione in formato X-Software e segnalare al versione nativamente portatile. A parte gli scherzi, l'installer da la possibilità di scegliere fra l'installazione normale e l'installazione "Portable", come specificato da vix. Quest'ultima si differenzia dalla nostra distribuzione solo perchè il profilo viene salvato nella sotto-cartella "Profiles". A parte questo aspetto, e qualche personalizzazione (ad esempio il backup del db, la copia del language pack preistorico e del plugin "modern contact list"), non ci sono grosse differenze. Se agli inconvenienti precedenti (legati al fatto che X-Launcher non può scrivere le impostazioni nel db) aggiungiamo anche che bisogna settare manualmente il percorso dei file ricevuti su %miranda_path%, gli inconvenienti aumentano. -- edit--- .. e corriamo il rischio di distribuire un X-Software NON portatile. Tanto vale segnalare quello originale (così non è colpa nostra.. )[ Edited Fri 14 May 2010 - 16:42 ] | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | RiRisposta: per me va bene, tanto non lo uso in nessuna versione... ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Idem. Boh.. aspettiamo qualche altro parere... Danix wrote ... -- edit--- .. e corriamo il rischio di distribuire un X-Software NON portatile. Tanto vale segnalare quello originale (così non è colpa nostra.. ) [ Edited Fri 14 May 2010 - 16:44 ] | ||
| Taf |
![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3379 ![]() | mi allineo a Danix e Zandet2! esiste già? perché "scornarsi" ?? ...così eliminiamo il problema alla radice. | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Miranda 0.8.23 Link winPenPack Aggiornamento dalla versione 0.8.22 alla 0.8.23 Home: -Link- ![]() Direct Link: not portable EXE (Windows NT, 2000, XP, Vista only) -Link- ![]() Direct Link: not portable ZIP (Windows NT, 2000, XP, Vista only) -Link- ![]() | ||
