![]() Go to page >> |
alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | X-Sunbird 0.7 RC2 ![]() Aggiornamento dalla versione 0.5 alla 0.7 RC2 Home: -Link- ![]() Direct Link En: not portable -Link- ![]() Direct Link It: not portable -Link- ![]() [ Edited Fri 19 Oct 2007 - 02:43 ] | ||
alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | X-Sunbird 0.7 RC3![]() Aggiornamento dalla versione 0.7 RC2 alla 0.7 RC3 Home: -Link- ![]() Direct Link En: not portable -Link- ![]() Direct Link It: not portable -Link- ![]() [ Edited Wed 24 Oct 2007 - 21:04 ] | ||
alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | X-Sunbird 0.7![]() Aggiornamento dalla versione 0.7 RC3 alla 0.7 Home: -Link- ![]() Direct Link En: not portable -Link- ![]() Direct Link It: not portable -Link- ![]() [ Edited Fri 04 Apr 2008 - 21:50 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Sunbird 0.8 Link winPenPack (ita) Link winPenPack (en) Aggiornamento dalla versione 0.7 alla 0.8 Home: -Link- ![]() Direct Link En: not portable -Link- ![]() Direct Link It: not portable -Link- ![]() [ Edited Sun 06 Apr 2008 - 11:10 ] | ||
Darklight79 |
![]() ![]() ![]() Registered Member #1005 Joined: Thu 25 Jan 2007 - 16:48Location: Cesena (FC) Posts: 111 | X-Sunbird 0.9 Link winPenPack (ita) Link winPenPack (en) Aggiornamento dalla versione 0.8 alla versione 0.9 Home: -Link- ![]() Direct Link It: (not portable) -Link- ![]() Direct Link En: (not portable) -Link- ![]() [ Edited Mon 27 Oct 2008 - 15:01 ] | ||
![]() ![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | X-Sunbird 1.0 b1 Link winPenPack (ita) Link winPenPack (en) Aggiornamento dalla versione 0.9 alla versione 1.0 b1 Home: -Link- ![]() Direct Link It: (not portable) web -Link- ![]() ![]() Direct Link En: (not portable) web -Link- ![]() ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Wed 21 Apr 2010 - 12:34 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | zandet2 wrote ... --- edit zandet2 --- software wpp aggiornato Ho notato che in questa versione possiamo eliminare:
Cos'è questa parte commentata?
;(application id from application.ini)
![]() ![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Danix wrote ... Ho notato che in questa versione possiamo eliminare:
Ok, nel prossimo aggiornamento lo eliminiamo. Cos'è questa parte commentata?
Le nuove versioni dei software Mozilla (anche Firefox fa così) creano una cartella in "@AppDataDir@\Mozilla\Extensions" con l'identificativo dell'applicazione, dove immagino vadano ad installare eventuali estensioni di sistema; credo sia dovuto alla nuova versione di Gecko, perchè anche Flock si comporta così pur non essendo Mozilla. Nella versione portabile sono cartelle vuote. La variabile l'ho inserita commentata insieme a:
[Functions]
e:
[RunAfter]
in analogia a quanto fatto per "@AppDataDir@\Mozilla\$AppName$", per tenere traccia di cartelle create sul pc ospite e tollerate nella portabilità. | ||
![]() ![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Richiesto test MOLTO importante: verificate se la nuova versione richiede .NET!!! Testato questa sera su XPSp3 senza .NET, e il programma non funziona, neanche nella versione installata: nella pagina di mozilla non vengono specificati requisiti particolari per il funzionamento. | ||
![]() ![]() ![]() ![]() Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3369 ![]() | Purtroppo all stato attuale non ho più nessuna macchina senza .net! Vedrò di provarlo quanto prima su una "virtual machine" pulita. Ti faccio sapere appena ho dati "certi". | ||
