Aggiornamento: X-Scite
Go to page   <<        >>
Sat 01 Apr 2017 - 14:11
Registered Member #675
X-Scite 3.7.4
Link winPenPack
Aggiornamento dalla versione 3.7.3 alla 3.7.4
Home: -Link-
Direct link: -Link-
Sat 27 May 2017 - 14:10
X-Scite 3.7.5
Link winPenPack
Aggiornamento dalla versione 3.7.4 alla 3.7.5
Home: -Link-
Direct link: -Link-
Fri 18 Aug 2017 - 22:04
X-Scite 4.0.0
Link winPenPack
Aggiornamento dalla versione 3.7.5 alla 4.0.0
Home: -Link-
Direct link: -Link-
Sat 29 Dec 2018 - 21:30
X-SciTE 4.1.2
Link winPenPack
SciTE Home: -Link-
SciTE Direct link: -Link-
rbon
Sun 03 May 2020 - 18:43
Registered Member #4134
X-SciTE 4.3.3
Link winPenPack -Link-
Home: -Link-
Direct download archive: -Link-
History: -Link-
rbon
Sun 28 Feb 2021 - 17:54
X-SciTE 4.4.6
SciTE web site: -Link-
Sourceforge project page: -Link-
Sourceforge.net download page for v4.4.6: -Link-
Direct download archive v4.4.6 for 32 bit: -Link-
Direct download archive v4.4.6 for 64 bit: -Link-
History: -Link-
[ Edited Sat 06 Mar 2021 - 20:02 ]
rbon
Sat 06 Mar 2021 - 19:42
X-SciTE 5.0.0
SciTE download page: -Link-
Direct download archive v5.0.0 for 32 bit: -Link-
Direct download archive v5.0.0 for 64 bit: -Link-
Sourceforge.net download page for v5.0.0: -Link-
History: -Link-
Softpedia: -Link-
Changelog for rel. 5.0.0:
• Released 5 March 2021.
• First version that separates Lexilla from Scintilla. Each of the 3 projects now has a separate history page but history before 5.0.0 remains combined.
• Fix Alt+End (move to wrapped line end) for Japanese UTF-8 text.. Bug #2231 -Link- .
• SciTE uses the "null" lexer when it doesn't have a lexer assigned to a file. This avoids activating a Lua script lexer if one is assigned.
Nota_1:
La versione 5.0.0 è una release instabile con i lexer disaggregati.
Nota_2:
Gli eseguibili di Windows supportano solo Windows XP e versioni successive. Potrebbe essere possibile creare con compilatori meno recenti per Windows 2000, ma non è più testato.
SciTE funziona su: Windows XP, Windows Vista, Windows 7, Windows 8.1 e Windows 10.
Nota_3:
richiesta di nuove funzionalità su Sourceforge.net: -Link- .
[ Edited Sun 07 Mar 2021 - 16:02 ]
Sat 24 Apr 2021 - 09:39
Registered Member #9
X-SciTE 5.0.2
Direct download archive v5.0.2 for 32 bit: -Link-
Direct download archive v5.0.2 for 64 bit: -Link-
Sourceforge.net download page for v5.0.2: -Link-
History: -Link-
[ Edited Sat 24 Apr 2021 - 09:40 ]
rbon
Wed 02 Jun 2021 - 20:43
X-SciTE 5.0.3
Sourceforge.net download page for v5.0.3: -Link-
Direct download archive v5.0.3 for 32 bit: -Link-
Direct download archive v5.0.3 for 64 bit: -Link-
History
on SciTE web site: -Link-
rbon
Fri 25 Jun 2021 - 20:07
X-SciTE 5.1.0
Sourceforge.net download page for v5.1.0: -Link-
Direct download archive v5.1.0 for 32 bit: -Link-
Direct download archive v5.1.0 for 64 bit: -Link-
Softpedia: -Link-
Nota
SciTE è alla base di Notepad++.
History
History details
• Released 23 June 2021.
• This is a stable release. Interfaces with lexers and between platform-independent code and platform layers should remain compatible through 5.x releases.
• Add SciFnDirectStatus, a direct access function which also returns status. It can be retrieved with SCI_GETDIRECTSTATUSFUNCTION. This can avoid calling SCI_GETSTATUS after every API to determine failure so can improve performance.
• Add more type-safe wrappers to the API. These are defined in include/ScintillaCall.h and implemented in call/ScintillaCall.cxx. ScintillaCall throws Scintilla::Failure exceptions when a call fails.
• Add APIs for setting appearance (traditional blob or plain text) and colour of representations and support setting a representation for the "\r\n" line end sequence.
• Add SCI_REPLACERECTANGULAR to insert text like a rectangular paste.
• Fixed bug with SCI_GETLASTCHILD. Bug #2260.
• Fixed gcc link-time-optimization (LTO) compilation. Bug #2259.
[ Edited Fri 25 Jun 2021 - 20:11 ]
Go to page   <<        >>
