Aggiornamento: X-Scite Go to page << >> |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Scite 3.7.4 Link winPenPack Aggiornamento dalla versione 3.7.3 alla 3.7.4 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Scite 3.7.5 Link winPenPack Aggiornamento dalla versione 3.7.4 alla 3.7.5 Home: -Link- Direct link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Scite 4.0.0 Link winPenPack Aggiornamento dalla versione 3.7.5 alla 4.0.0 Home: -Link- Direct link: -Link- | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | X-SciTE 4.1.2 Link winPenPack SciTE Home: -Link- SciTE Direct link: -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | X-SciTE 4.3.3 Link winPenPack -Link- Home: -Link- Direct download archive: -Link- History: -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | X-SciTE 4.4.6 Link winPenPack -Link- SciTE web site: -Link- Sourceforge project page: -Link- Sourceforge.net download page for v4.4.6: -Link- Direct download archive v4.4.6 for 32 bit: -Link- Direct download archive v4.4.6 for 64 bit: -Link- History: -Link- [ Edited Sat 06 Mar 2021 - 20:02 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | X-SciTE 5.0.0 Link winPenPack -Link- SciTE web site: -Link- SciTE download page: -Link- Direct download archive v5.0.0 for 32 bit: -Link- Direct download archive v5.0.0 for 64 bit: -Link- Sourceforge.net download page for v5.0.0: -Link- History: -Link- Softpedia: -Link- Changelog for rel. 5.0.0: • Released 5 March 2021. • First version that separates Lexilla from Scintilla. Each of the 3 projects now has a separate history page but history before 5.0.0 remains combined. • Fix Alt+End (move to wrapped line end) for Japanese UTF-8 text.. Bug #2231 -Link- . • SciTE uses the "null" lexer when it doesn't have a lexer assigned to a file. This avoids activating a Lua script lexer if one is assigned. Nota_1: La versione 5.0.0 è una release instabile con i lexer disaggregati. Nota_2: Gli eseguibili di Windows supportano solo Windows XP e versioni successive. Potrebbe essere possibile creare con compilatori meno recenti per Windows 2000, ma non è più testato. SciTE funziona su: Windows XP, Windows Vista, Windows 7, Windows 8.1 e Windows 10. Nota_3: richiesta di nuove funzionalità su Sourceforge.net: -Link- . [ Edited Sun 07 Mar 2021 - 16:02 ] | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1724 | X-SciTE 5.0.2 Link winPenPack -Link- SciTE web site: -Link- SciTE download page: -Link- Direct download archive v5.0.2 for 32 bit: -Link- Direct download archive v5.0.2 for 64 bit: -Link- Sourceforge.net download page for v5.0.2: -Link- History: -Link- [ Edited Sat 24 Apr 2021 - 09:40 ] | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | X-SciTE 5.0.3 Link winPenPack -Link- SciTE web site: -Link- SciTE download page: -Link- Sourceforge.net download page for v5.0.3: -Link- Direct download archive v5.0.3 for 32 bit: -Link- Direct download archive v5.0.3 for 64 bit: -Link- History on SciTE web site: -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | X-SciTE 5.1.0 Link winPenPack -Link- SciTE web site: -Link- SciTE download page: -Link- Sourceforge.net download page for v5.1.0: -Link- Direct download archive v5.1.0 for 32 bit: -Link- Direct download archive v5.1.0 for 64 bit: -Link- Softpedia: -Link- Nota SciTE è alla base di Notepad++. History on SciTE web site: -Link- History details • Released 23 June 2021. • This is a stable release. Interfaces with lexers and between platform-independent code and platform layers should remain compatible through 5.x releases. • Add SciFnDirectStatus, a direct access function which also returns status. It can be retrieved with SCI_GETDIRECTSTATUSFUNCTION. This can avoid calling SCI_GETSTATUS after every API to determine failure so can improve performance. • Add more type-safe wrappers to the API. These are defined in include/ScintillaCall.h and implemented in call/ScintillaCall.cxx. ScintillaCall throws Scintilla::Failure exceptions when a call fails. • Add APIs for setting appearance (traditional blob or plain text) and colour of representations and support setting a representation for the "\r\n" line end sequence. • Add SCI_REPLACERECTANGULAR to insert text like a rectangular paste. • Fixed bug with SCI_GETLASTCHILD. Bug #2260. • Fixed gcc link-time-optimization (LTO) compilation. Bug #2259. [ Edited Fri 25 Jun 2021 - 20:11 ] | ||
