![]() Go to page >> |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.6.0-beta1 Link winPePack Aggiornamento dalla versione 1.5.0.2 alla 1.6.0-beta1 Home: -Link- ![]() Direct link: -Link- ![]() [ Edited Tue 12 Feb 2008 - 09:08 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.6.0-beta2 Link winPePack Aggiornamento dalla versione 1.6.0-beta1 alla 1.6.0-beta2 Home: -Link- ![]() Direct link: -Link- ![]() [ Edited Tue 12 Feb 2008 - 09:08 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12926 ![]() | X-Mixxx 1.6.1 Link winPenPack Aggiornamento dalla versione 1.6.0-beta2 alla 1.6.1 Home: -Link- ![]() Direct link (not portable): -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.7.0 Link winPenPack Aggiornamento dalla versione 1.6.1 alla 1.7.0 Home: -Link- ![]() Direct link (not portable): -Link- ![]() [ Edited Sat 08 Aug 2009 - 16:06 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.7.1 Link winPenPack Aggiornamento dalla versione 1.7.0 alla 1.7.1 Home: -Link- ![]() Direct link (not portable): -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Tue 17 Nov 2009 - 21:57 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.7.2 Link winPenPack Aggiornamento dalla versione 1.7.1 alla 1.7.2 Home: -Link- ![]() Direct link (not portable): -Link- ![]() --- edit zandet2 --- software wpp aggiornato [ Edited Sat 09 Jan 2010 - 20:08 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.8.0 Link winPenPack Aggiornamento dalla versione 1.7.2 alla 1.8.0 Home: -Link- ![]() Direct link (not portable): -Link- ![]() --- edit zandet2 --- software wpp aggiornato con launcher 1.4.2 [ Edited Fri 15 Oct 2010 - 19:15 ] | ||
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.8.1 Link winPenPack Aggiornamento dalla versione 1.8.0 alla 1.8.1 Home: -Link- ![]() Direct link (not portable): -Link- ![]() --- edit zandet2 --- software wpp aggiornato con indicazioni post sotto [ Edited Thu 21 Oct 2010 - 21:32 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12926 ![]() | @zandet2, se fai prima tu, nel launcher va inserita questa parte:
DirRemove=@UserProfileDir@\Local Settings\Application Data|e
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | X-Mixxx 1.8.2 Link winPenPack Aggiornamento dalla versione 1.8.1 alla 1.8.2 Home: -Link- ![]() Direct link (not portable): -Link- ![]() | ||
