![]() Go to page >> |
icemax |
![]() ![]() ![]() Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 ![]() | Nome Software:USB Disk Ejector Direct Link al download: -Link- ![]() Dimensione File: 487 KB (499,200) Nome autore: Bgbennyboy eMail autore: .. Sito Web Autore: -Link- ![]() Descrizione: USB Disk Ejector è un’utility gratuita che permette di rimuovere le periferiche Usb connesse al sistema con un semplice doppio-click. Molto precisa nello scegliere la periferica da rimuovere rispetto all'utility di windows. Supporta inoltre la linea di comando (vedi info originali) Portable tips how-to: applicazione totalmente Portatile Versione:1.1 Licenza:Open Source Sorgenti disponibili per DELPHI 2007 qui : Download Source of USB Disk Ejector screenshot : ![]() info originali : Current Version: 1.1 A program that allows you to quickly remove USB devices in Windows. It was originally designed to remove only USB pen drives but will now eject any USB device. It can be run as a non-visual command line program or a normal gui program. Its very useful if you have a USB flash/pen drive, especially if you use a menu such as Pstart or the Portable Apps launcher. The command line options are very flexible, they can be used to: • Eject the drive that the program is running from. • Eject a drive by specifying a drive letter. • Eject a drive by specifying a drive name. • Eject a drive by specifying a partial drive name. When run as a ‘normal’ GUI program the tools enables USB devices to be quickly ejected through a mouse click or keyboard press. It’s especially useful when dealing with multiple USB devices and for Vista users who don’t want the ‘now safe to remove this device’ dialog box to appear. The program has been tested on WindowsXP and Windows Vista but should also work on older versions of Windows. source page for application by Bgbennyboy here | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12961 ![]() | Ottimo! Se non è possibile integrarlo nel menù sarà inserito di serie in tutti i winPenPack ![]() Informazioni precise sulla licenza? [ Edited Wed 09 Jan 2008 - 12:03 ] | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Ciao Danix, no, perché? Il programma può essere utilizzato anche dal pendrive da sconnettere • Eject the drive that the program is running from. e si può mettere nel menu eseguendolo all'uscita. Non ho ancora provato, ma secondo te, perché non dovrebbe funzionare? Cordialmente ZioZione | ||
![]() ![]() ![]() Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 ![]() | Ciao Danix, che succede? Ti ho risposto ad un post che non dovrebbe ancora esserci, quindi risulto prima... e, credo, anche con questo post... Problemi all'orologio del server? Cordialmente ZioZione | ||
El Salvador |
![]() ![]() ![]() Registered Member #301 Joined: Mon 22 Jan 2007 - 12:58Posts: 396 ![]() | wrote ... Informazioni precise sulla licenza? Infatti non ci sono (o almeno non le ho trovate) e mi sembra che un software senza licenza, vada automaticamente sotto copyright, quindi non open source. | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12961 ![]() | ZioZione, non è che hai risposto su un altro topic? | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12961 ![]() | Non capisco che succede!!! Come mai i post vanno prima dell'ultimo? | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12961 ![]() | Si forse è l'orologio del server..... | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12961 ![]() | Ripensandoci.... ho detto una bella scemenza... ![]() Come si fa a disattivare la periferica se il programma è nel menù, che quindi non può essere chiuso, né tantomeno disattivato? Mi sembra del tutto inutile... USB Disk Ejector deve stare sul pc ![]() | ||
MAXPC72 |
![]() ![]() Registered Member #4454 Joined: Mon 30 Apr 2007 - 16:35Posts: 88 | io finora ho usato questo: USBDeview -Link- ![]() lo ho messo nel menu', quando chiudo il wpp mi parte l'applicazione e disconnetto la penna, poi spengo il pc. pero' in effetti uso il wpp su pc... [ Edited Wed 09 Jan 2008 - 13:09 ] | ||
