[Utility USB] USB Disk Ejector [Open Source]Vai a pagina >> |
| icemax |
![]() ![]() Utente registrato #194 Registrato il: dom 21 gen 2007 - 22:27Messaggi: 1371 ![]() | Nome Software:USB Disk Ejector Direct Link al download: -Link- ![]() Dimensione File: 487 KB (499,200) Nome autore: Bgbennyboy eMail autore: .. Sito Web Autore: -Link- ![]() Descrizione: USB Disk Ejector è un’utility gratuita che permette di rimuovere le periferiche Usb connesse al sistema con un semplice doppio-click. Molto precisa nello scegliere la periferica da rimuovere rispetto all'utility di windows. Supporta inoltre la linea di comando (vedi info originali) Portable tips how-to: applicazione totalmente Portatile Versione:1.1 Licenza:Open Source Sorgenti disponibili per DELPHI 2007 qui : Download Source of USB Disk Ejector screenshot : ![]() info originali : Current Version: 1.1 A program that allows you to quickly remove USB devices in Windows. It was originally designed to remove only USB pen drives but will now eject any USB device. It can be run as a non-visual command line program or a normal gui program. Its very useful if you have a USB flash/pen drive, especially if you use a menu such as Pstart or the Portable Apps launcher. The command line options are very flexible, they can be used to: • Eject the drive that the program is running from. • Eject a drive by specifying a drive letter. • Eject a drive by specifying a drive name. • Eject a drive by specifying a partial drive name. When run as a ‘normal’ GUI program the tools enables USB devices to be quickly ejected through a mouse click or keyboard press. It’s especially useful when dealing with multiple USB devices and for Vista users who don’t want the ‘now safe to remove this device’ dialog box to appear. The program has been tested on WindowsXP and Windows Vista but should also work on older versions of Windows. source page for application by Bgbennyboy here | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Ottimo! Se non è possibile integrarlo nel menù sarà inserito di serie in tutti i winPenPack Informazioni precise sulla licenza? [ Modificato mer 09 gen 2008 - 12:03 ] | ||
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 ![]() | Ciao Danix, no, perché? Il programma può essere utilizzato anche dal pendrive da sconnettere • Eject the drive that the program is running from. e si può mettere nel menu eseguendolo all'uscita. Non ho ancora provato, ma secondo te, perché non dovrebbe funzionare? Cordialmente ZioZione | ||
![]() ![]() ![]() Utente registrato #74 Registrato il: dom 21 gen 2007 - 11:31Provenienza: Tradate (VA) Messaggi: 3821 ![]() | Ciao Danix, che succede? Ti ho risposto ad un post che non dovrebbe ancora esserci, quindi risulto prima... e, credo, anche con questo post... Problemi all'orologio del server? Cordialmente ZioZione | ||
| El Salvador |
![]() ![]() ![]() Utente registrato #301 Registrato il: lun 22 gen 2007 - 12:58Messaggi: 396 ![]() | ha scritto ... Informazioni precise sulla licenza? Infatti non ci sono (o almeno non le ho trovate) e mi sembra che un software senza licenza, vada automaticamente sotto copyright, quindi non open source. | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | ZioZione, non è che hai risposto su un altro topic? | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Non capisco che succede!!! Come mai i post vanno prima dell'ultimo? | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Si forse è l'orologio del server..... | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Ripensandoci.... ho detto una bella scemenza... Come si fa a disattivare la periferica se il programma è nel menù, che quindi non può essere chiuso, né tantomeno disattivato? Mi sembra del tutto inutile... USB Disk Ejector deve stare sul pc ![]() | ||
| MAXPC72 |
![]() ![]() Utente registrato #4454 Registrato il: lun 30 apr 2007 - 16:35Messaggi: 88 | io finora ho usato questo: USBDeview -Link- ![]() lo ho messo nel menu', quando chiudo il wpp mi parte l'applicazione e disconnetto la penna, poi spengo il pc. pero' in effetti uso il wpp su pc... [ Modificato mer 09 gen 2008 - 13:09 ] | ||
