[Audio Catalog] Jampal mp3 library |
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Nome del software: Jampal mp3 library Direct Link al download: -Link- ![]() Dimensione File: 1291082 Nome autore: Peter G Bennett eMail autore: pgbennett at users.sourceforge.net Sito Web Autore: -Link- ![]() Descrizione: Catalogatore/gestore collezione mp3 Portable tips how-to: Decomprimere lo zip Versione: 1.14 Licenza: GPL Requirements: Java Quoto dal sito: Jampal offers some unique advantages over the other jukebox and mp3 player programs available. * Jampal stores a music library of over 22000 songs with ease. * You can sort, organize and categorize your tracks. * It is very fast. You can sort 12000 tracks in under a second. * You can update hundreds of track tags in one operation in a few seconds. * Jampal libraries can be easily customized so that you can organize your music any way you want to. * You can create your own frames within the ID3v2 standard to categorize your songs which ever way you want. * The library can be imported into a spreadsheet or text editor program. * Musicmatch Jukebox libraries can be converted to Jampal and vice versa. * Most ID3v2 fields are supported, including all text fields and any number of attached pictures. * Reference information from the ID3v2 standard is included to help understand the purpose and usage of each frame. * Synthesized voice announcements of song titles (on all platforms). Vincoli alla portabilità Richiede che il file di configurazione principale jampal_initial.properties risieda obbligatoriamente nella cartella .jampal, che si posiziona al primo avvio in "C:\Documents and Settings\NomeUtente", creando anche il primo database vuoto con il nome "default". Bisognerebbe riuscire a reindirizzare la cartella .jampal nella struttura x-portabile standard WPP\User, ma essendo Java (di cui non capisco nulla) non so come fargli digerire la parametrizzazione. Allego l'ini che ho preparato (velocemente) per la portabilizzazione e il contenuto della cartella .jampal creata al primo avvio: x-jampal_ini.zip | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | La lingua italiana non è supportata? INI:
[ Edited Wed 09 Jan 2008 - 18:41 ] | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Danix wrote ... La lingua italiana non è supportata? Mi sembra di no, anzi credo proprio che non gestisca nessuna lingua all'infuori dell'inglese.... | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Ho apportato una variazione all'ini poichè nel file di configurazione jampal_initial.properties viene scritto l'indirizzo assoluto della libreria in cui è memorizzato il database da aprire all'avvio del programma: jampal_initial.properties #Thu Jan 10 11:52:45 CET 2008 listen-port=25000 open-libraries=G\:\\winPenPack\\User\\Jampal\\.jampal\\mxp mixer-gainv5=0 speech-engine=None look-and-feel=javax.swing.plaf.metal.MetalLookAndFeel INI [Setup] AppName=Jampal [FileToRun] PathToExe=$Lib$\Java\bin\javaw.exe Parameters=-Duser.home=../../User/$AppName$ -jar jampal.jar WorkingDir=%JampalInstallDir% [Environment] JampalInstallDir=$Bin$\$AppName$ [Functions] DirCreate=$Home$\$AppName$ [StringReplace=$Home$\$AppName$\.jampal\jampal_initial.properties] open-libraries|.jampal==$Home$\$AppName$\|\\ [Options] DeleteTemp=true MultipleIstances=true RunWait=true ShowSplash=false | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Grazie, corretto -Link- ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Scrive i file recenti nel registro:
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Siamo arrivati alla [rev5] -Link- (con parecchie limitazioni -Link- ) | ||
