Aggiornamento: Unforgiven Organizer PortableGo to page >> |
| alchimista |
![]() ![]() Registered Member #3875 Joined: Fri 06 Apr 2007 - 09:34Posts: 1299 ![]() | Unforgiven Organizer Portable 5.7 ![]() Aggiornamento dalla versione 5.5 alla 5.7 Home: -Link- ![]() Direct Link: -Link- ![]() [ Edited Tue 27 Jul 2010 - 10:07 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Unforgiven Organizer Portable 5.8![]() Aggiornamento dalla versione 5.7 alla 5.8 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: non testato | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Test: -Link- ![]() | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Unforgiven Organizer Portable 5.9 Link winPenPack Aggiornamento dalla versione 5.8 alla 5.9 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: Spoiler: [ Edited Thu 14 Jan 2010 - 23:16 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Unforgiven Organizer Portable 60 Link winPenPack Aggiornamento dalla versione 59 alla 60 Home: -Link- ![]() Direct Link: -Link- ![]() Risultato test: identico alla versione precedente. [ Edited Fri 23 Apr 2010 - 15:54 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Unforgiven Organizer Portable 61 Link winPenPack Aggiornamento dalla versione 60 alla 61 Home: -Link- ![]() Download page: -Link- ![]() Risultato test: ![]() [ Edited Tue 27 Jul 2010 - 11:35 ] | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Software in stato di pending: estraendo e avviando la versione portabile, ottengo l'errore "uOrganizer.exe has encountered a problem and needs to close. We are sorry for the inconvenience." Qualcun altro potrebbe effettuare una verifica? Va tenuto presente che la nostra scheda software non è aggiornata, in quanto punta al sito esterno del produttore dove è già in download la nuova versione (e non sono disponibili versioni precedenti). | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | zandet2 wrote ... Qualcun altro potrebbe effettuare una verifica? A me si è avviato correttamente. Piuttosto, il direct link, sia qui nel forum che nella sezione download non è consentito, quindi va inserito il link alla pagina di download presente sul sito del produttore. | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Danix wrote ... A me si è avviato correttamente. Piuttosto, il direct link, sia qui nel forum che nella sezione download non è consentito, quindi va inserito il link alla pagina di download presente sul sito del produttore. Allora forse dipende da configurazioni del mio pc (XP Pro sp3 con utenza limitata); aggiorno e correggo la scheda di download. | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Unforgiven Organizer Portable 62 Link winPenPack Aggiornamento dalla versione 61 alla 62 Home: -Link- ![]() Download page: -Link- ![]() Risultato test: Spoiler: [ Edited Mon 08 Nov 2010 - 22:53 ] | ||
