Aggiornamento: Unforgiven Organizer PortableGo to page << >> |
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Unforgiven Organizer 63 Link winPenPack Aggiornamento dalla versione 62 alla 63 Home: -Link- ![]() Download page: -Link- ![]() Risultato test: Spoiler: | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Unforgiven Organizer 64 Link winPenPack Aggiornamento dalla versione 63 alla 64 Home: -Link- ![]() Download page: -Link- ![]() Risultato test: Spoiler: [ Edited Mon 16 Jan 2012 - 23:02 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Unforgiven Organizer 65 Link winPenPack Aggiornamento dalla versione 64 alla 65 Home: -Link- ![]() Download page: -Link- ![]() Risultato test: Spoiler: | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Unforgiven Organizer 66 Link winPenPack Aggiornamento dalla versione 65 alla 66 Home: -Link- ![]() Download page: -Link- ![]() Risultato test: Spoiler: | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Unforgiven Organizer 67 Link winPenPack Aggiornamento dalla versione 66 alla 67 Home: -Link- ![]() Download page: -Link- ![]() Risultato test: Spoiler: | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Unforgiven Organizer 68 Link winPenPack Aggiornamento dalla versione 67 alla 68 Home: -Link- ![]() Download page: -Link- ![]() Risultato test: Spoiler: [ Edited Thu 05 Apr 2012 - 15:17 ] | ||
| Rcs |
![]() ![]() ![]() ![]() Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 ![]() | Unforgiven Organizer 69 Link winPenPack Aggiornamento dalla versione 68 alla 69 Home: -Link- ![]() Download page: -Link- ![]() Risultato test: Spoiler: | ||
| Bourne |
![]() ![]() Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 571 ![]() | Rcs wrote ... Unforgiven Organizer 69 Link winPenPack Aggiornamento dalla versione 68 alla 69 Home: -Link- ![]() Download page: -Link- ![]() Risultato test: Spoiler: Domanda: in archivio avete messo la versione portable e questo è il thread dell'aggiornamento di Unforgiven Organizer PORTABLE, quindi se ne deduce che il risultato del test portabilità, con le varie chiavi che lascia nel registro, sia riferito a questa versione portabile di Unforgiven Organizer, giusto? Se sì, allora perché avete messo in archivio una versione portabile che non è tale e che quindi si suppone abbia bisogno di X-Launcher? | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | Ciao Bourne, il programma è freeware (anzi, sisterware ), quindi la licenza ci impedisce di mettere in pista una versione X-Portabile.In qualunque caso, le chiavi segnalate sono considerate "tollerate" in quanto legate alla gestione della compatibilità delle esecuzioni su windows 64bit di programmi nativi 32bit (vedi qui -Link- )Ciao! [ Edited Thu 04 Oct 2012 - 12:08 ] | ||
| Bourne |
![]() ![]() Registered Member #4287 Joined: Fri 20 Apr 2007 - 16:55Posts: 571 ![]() | zandet2 wrote ... il programma è freeware (anzi, sisterware ), quindi la licenza ci impedisce di mettere in pista una versione X-Portabile.Ah ok. zandet2 wrote ... In qualunque caso, le chiavi segnalate sono considerate "tollerate" in quanto legate alla gestione della compatibilità delle esecuzioni su windows 64bit di programmi nativi 32bit Qua la questione mi sembra diversa: non parliamo delle chiavi tipiche della gestione dei win più recenti (tipo rca_tracing, ecc.), ma bensì di chiavi legate al software stesso (vedi "Borland") che in questo stesso forum farebbero etichettare il programma come non portabile (per esempio, anche se il programma girasse su un sistema 32 bit, immagino che anche lì apparirebbe la chiave "Borland"), un po' come quei programmi che usano le librerie QT. | ||
