[Collection] freeware by WWW_JOERN-THIEMANN_DE Go to page >> |
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | Ciao forum..ciao staff...e un tappeto rosso a Danix ..meriti un [] ø una recensione di piccolissimi ma utili programmi totalmente portatili home dei programmi : -Link- ø Dyn-Up (Dynamic IP-Updater) With this tool you are able to synchronize your IP with a FTP-Server. You are able to run your own dynamic web-server. This tool is optimized for a router (for example DSL router) with web-interface. Dyn-Up does the following for you: • get your "Outside"-IP from the router • send the IP to one program • integrated FTP-Server for updating several files • Dyn-Up ships with a tool which is able to replace date, time and IP in several html-files before uploading to your ftp-server download : -Link- ø SSMM - Slide Show Movie Maker Slide Show Movie Maker is a free program that can create an AVI-file from a series of .bmp or .jpg images. Images can have professional-looking fade-in and fade-out effects, plus attractive text overlays. The program's clean-looking interface is logically laid out; you should become productive within just a few minutes of running it. Keep in mind that .avi files can become quite large and take a long time to render. However, Slide Show Maker lets you choose to save output using any one of your system's installed .avi codecs, so the file size and generation time will vary depending upon which one you choose. Operating System: Windows 9x, NT, ME, 2000, XP, XP Pro with a resolution with minimal 1024 x 768 pixel (some controls are not shown at a smaller resolution) Import (Images / Videos): 24-Bit BMP, JPG, AVI Import (Audio): WAV (16-Bit Stereo 44,1 Khz PCM) Export: AVI (Audio Video Interleave) Current supported languages are: English (3.7), German (3.7), French (3.5.3), Spanish (3.2.2), Dutch (3.5.3), Danish (3.2.2), Portuguese (3.2.2) , Japanese (3.6) (screenshot), Brazil Portuguese (3.6), Traditional Chinese (3.6), Simplified Chinese (3.6), Catalan (3.6) * italiano = [armatevi di buona pazienza e..create il file ..ed eseguite l'upload su winpenpack ..thanks] download -Link- ø ProjectDivX [in italiano] Merge your DivX MPEG 4 AVIs (encoded in DivX-Low and DivX-Fast) very easily. You can also cut big AVIs into smaller parts. -Link- ø StreamManager you are able to create a new AVI, using the videostream of one AVI and the audiostream of one AVI. StreamManager merges them to a new AVI without compressing it again download : -Link- | ||
deep |
Registered Member #7 Joined: Sat 20 Jan 2007 - 20:57Posts: 568 | mmm... i links non vanno. | ||
simongr |
Registered Member #23 Joined: Sat 20 Jan 2007 - 23:54Posts: 858 | Neanche a me! | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1722 | Anche a me, a quanto sembra è tutto il sito che ha fatto kaputt. | ||
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | si ho visto ..il sito è down ..quindi : posto qui i files : 865 kb : contents :
spero di aver fatto cosa gradita !! 1169973804_194_FT206_winpenpack.rar | ||
deep |
Registered Member #7 Joined: Sat 20 Jan 2007 - 20:57Posts: 568 | Ottimo, grazie! | ||
eagleman |
Registered Member #9 Joined: Sat 20 Jan 2007 - 21:36Location: Veglie Posts: 1722 | Se ho un po' di tempo preparo anche la lingua italiana per slideshow moviemaker | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | ICE, forse sarebbe il caso di eliminare i link.... il sito di riferimento sembra definitivamente KO! | ||
simongr |
Registered Member #23 Joined: Sat 20 Jan 2007 - 23:54Posts: 858 | Beh...che possa essere down da piu di 4 giorni mi pare difficile ma non impossibile. Vediamo un po se si riprende! | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | Dove tieni il "Rianimatore da viaggio"?? LOL | ||
