[Collection] freeware by WWW_JOERN-THIEMANN_DE
icemax
sab 27 gen 2007 - 15:55
Utente registrato #194
Ciao forum..ciao staff...e un tappeto rosso a Danix ..meriti un []
ø una recensione di piccolissimi ma utili programmi totalmente portatili
home dei programmi : -Link-
ø Dyn-Up (Dynamic IP-Updater)
With this tool you are able to synchronize your IP with a FTP-Server.
You are able to run your own dynamic web-server. This tool is optimized for a
router (for example DSL router) with web-interface. Dyn-Up does the following
for you:
• get your "Outside"-IP from the router
• send the IP to one program
• integrated FTP-Server for updating several files
• Dyn-Up ships with a tool which is able to replace date, time and IP
in several html-files before uploading to your ftp-server
download : -Link-
ø SSMM - Slide Show Movie Maker
Slide Show Movie Maker is a free program that can create an AVI-file from a
series of .bmp or .jpg images. Images can have professional-looking fade-in
and fade-out effects, plus attractive text overlays. The program's clean-looking interface is logically laid out; you should become productive within
just a few minutes of running it. Keep in mind that .avi files can become quite
large and take a long time to render. However, Slide Show Maker lets you
choose to save output using any one of your system's installed .avi codecs,
so the file size and generation time will vary depending upon which one
you choose.
Operating System: Windows 9x, NT, ME, 2000, XP, XP Pro with a resolution
with minimal 1024 x 768 pixel (some controls are not shown at a smaller
resolution)
Import (Images / Videos): 24-Bit BMP, JPG, AVI
Import (Audio): WAV (16-Bit Stereo 44,1 Khz PCM)
Export: AVI (Audio Video Interleave)
Current supported languages are: English (3.7), German (3.7), French (3.5.3),
Spanish (3.2.2), Dutch (3.5.3), Danish (3.2.2), Portuguese (3.2.2) ,
Japanese (3.6) (screenshot), Brazil Portuguese (3.6), Traditional Chinese (3.6),
Simplified Chinese (3.6), Catalan (3.6)
* italiano = [armatevi di buona pazienza e..create il file ..ed eseguite l'upload
su winpenpack ..thanks]
download -Link-
ø ProjectDivX [in italiano]
Merge your DivX MPEG 4 AVIs (encoded in DivX-Low and DivX-Fast)
very easily. You can also cut big AVIs into smaller parts.
ø StreamManager
you are able to create a new AVI, using the videostream of one AVI and the
audiostream of one AVI.
StreamManager merges them to a new AVI without compressing it again
download :
deep
sab 27 gen 2007 - 17:20
Utente registrato #7
mmm... i links non vanno.
simongr
sab 27 gen 2007 - 22:55
Utente registrato #23
Neanche a me!
sab 27 gen 2007 - 22:57
Utente registrato #9
Provenienza: Veglie
Anche a me, a quanto sembra è tutto il sito che ha fatto kaputt.
icemax
dom 28 gen 2007 - 09:43
si ho visto ..il sito è down ..quindi :
posto qui i files :
865 kb :
contents :
  [list]
 - [b]Dyn-Up 1.0[/b]
 - [b]SSMM 3.7[/b]
 - [b]StreamManager[/b]
  [/list]
spero di aver fatto cosa gradita !!
1169973804_194_FT206_winpenpack.rar
deep
dom 28 gen 2007 - 16:00
Ottimo, grazie!
dom 28 gen 2007 - 16:36
Provenienza: Veglie
Se ho un po' di tempo preparo anche la lingua italiana per slideshow moviemaker
mar 30 gen 2007 - 09:46
ICE, forse sarebbe il caso di eliminare i link.... il sito di riferimento sembra definitivamente KO!
simongr
mar 30 gen 2007 - 12:32
Beh...che possa essere down da piu di 4 giorni mi pare difficile ma non impossibile.
Vediamo un po se si riprende!
mar 30 gen 2007 - 12:58
Dove tieni il "Rianimatore da viaggio"?? LOL
