Virus in winPenPack 3.4?Go to page << >> |
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | ------------------------------ REGCLEAR.exe ------------------------------ Il problema deriva dalla compressione con UPX. Report di VirusTotal sul file compresso: -Link- ![]() Report di VirusTotal sul file decompresso: -Link- ![]() Fix: regclear_no_upx.zip(sovrascrivere il file REGCLEAR.exe nella cartella \winPenPack\Bin\wpp_pampa\PAMPA) (overwrite REGCLEAR.exe into \winPenPack\Bin\wpp_pampa\PAMPA folder) [ Edited Tue 09 Sep 2008 - 13:53 ] | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | ------------------ cp950.so ------------------ Segnalata (via eMail) la presenza del file sospetto cp950.so incluso in /winPenPack/Bin/wpp_pampa/PAMPA/apache/bin/iconv/cp950.so Il problema deriva dalla compressione con UPX. Report di VirusTotal sul file compresso -Link- ![]() Report di VirusTotal sul file decompresso: -Link- ![]() Fix: cp950.so_no_upx.zip(sovrascrivere il file cp950.so nella cartella \winPenPack\Bin\wpp_pampa\PAMPA\apache\bin\iconv\) (overwrite cp950.so into \winPenPack\Bin\wpp_pampa\PAMPA\apache\bin\iconv\ folder) | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | -------------------------- libthinice.dll -------------------------- Il problema deriva dalla compressione con UPX. Report di VirusTotal sul file compresso -Link- ![]() Report di VirusTotal sul file decompresso: -Link- ![]() libthinice.dll_no_upx.zip(sovrascrivere il file libthinice.dll nella cartella \winPenPack\Lib\GTK\lib\gtk-2.0\2.10.0\engines\) (overwrite libthinice.dll into \\winPenPack\Lib\GTK\lib\gtk-2.0\2.10.0\engines\ folder) | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | ---------------------------------------------------- Easy Screen Capture.exe ---------------------------------------------------- Il problema deriva dalla compressione con UPX. Report di VirusTotal sul file compresso -Link- ![]() Report di VirusTotal sul file decompresso: -Link- ![]() easy_screen_capture_exe_no_upx.zip(sovrascrivere il file "Easy Screen Capture.exe" nella cartella \winPenPack\Bin\Easy Screen Capture\) (overwrite "Easy Screen Capture.exe" into \winPenPack\Bin\Easy Screen Capture\ folder) | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | ---------------- xCollect.exe ---------------- Altra segnalazione effettuata via e-mail (nonostante abbia scritto dappertutto che bisogna utilizzare il forum, continuo a ricevere segnalazioni via mail!! ). Avast antivirus rileva "Win32:Trojan-gen {Other}" has been found in xCollect.exe".Questo è il report di VirusTotal (l'eseguibile non è compresso con UPX) -Link- ![]() Non trovo info a riguardo in rete. Qualche idea? | ||
| zandet2 |
![]() ![]() ![]() Registered Member #3184 Joined: Tue 06 Mar 2007 - 11:52Location: Busto Arsizio Posts: 3301 ![]() | ---------------------- emule.exe ---------------------- Il problema deriva dalla compressione con UPX. Report di VirusTotal sul file compresso -Link- ![]() Report di VirusTotal sul file decompresso: -Link- ![]() emule_noupx.zip(sovrascrivere il file "emule.exe" nella cartella \winPenPack\Bin\emule\) (overwrite "emule.exe" into \winPenPack\Bin\emule\ folder) | ||
| Simoilmito |
![]() ![]() Registered Member #10098 Joined: Sat 29 Mar 2008 - 18:47Location: Brescia Posts: 1 | ciao a tutti, grazie per la segnalazione di emule [ Edited Sat 04 Oct 2008 - 18:14 ] | ||
| paolo.cavallari |
![]() ![]() Registered Member #14355 Joined: Thu 16 Oct 2008 - 12:17Posts: 6 | molte grazie sono riuscito | ||
| domino |
![]() ![]() ![]() Registered Member #9897 Joined: Fri 21 Mar 2008 - 17:57Location: Milano Posts: 600 ![]() | Ciao a tutti, oggi ho provato X-Simple Machine Protect 1.7.5 , volevo aggiornarmi da solo questo programma ma Avast mi ha dato segnalazione del solito problema dovuto alla compressione UPX. File: SMP.EXE Virus: Win32:Trojan-gen {Other} Tipologia: Virus/Worm Aggiornamento VPS: 081017-0, 17/10/2008 volevo allegarvi il log di Virus Total ma il servizio non va. | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Il programma originale ha lo stesso problema? | ||
