Aggiornamento: CoolPlayer
Sat 31 May 2008 - 21:54
Registered Member #675
CoolPlayer 218
Link winPenPack
Aggiornamento dalla versione 217 alla 218
Home: -Link-
Direct link: -Link-
Risultato test:
Scrive le chiavi HKLM\SOFTWARE\Classes
Sat 31 May 2008 - 23:05
Rcs wrote ...
\Classes... e poi?
Sat 31 May 2008 - 23:11
Chiave aggiunta:22
HKLM\SOFTWARE\Classes\Folder\shell\CoolPlayer Play
HKLM\SOFTWARE\Classes\Folder\shell\CoolPlayer Play\command
HKLM\SOFTWARE\Classes\Folder\shell\CoolPlayer Queue
HKLM\SOFTWARE\Classes\Folder\shell\CoolPlayer Queue\command
HKLM\SOFTWARE\Classes\CoolPlayer.Audio
HKLM\SOFTWARE\Classes\CoolPlayer.Audio\DefaultIcon
HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell
HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell\CoolPlayer Play
HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell\CoolPlayer Play\command
HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell\CoolPlayer Queue
HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell\CoolPlayer Queue\command
HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell\Open
HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell\Open\command
HKLM\SOFTWARE\Classes\CoolPlayer.Playlist
HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\DefaultIcon
HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell
HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell\CoolPlayer Play
HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell\CoolPlayer Play\command
HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell\CoolPlayer Queue
HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell\CoolPlayer Queue\command
HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell\Open
HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell\Open\command
Sat 31 May 2008 - 23:25
Non c'è modo di evitare la scrittura di quelle chiavi?
Che so... inserendo il solito file vuoto, o non selezionando alcune opzioni..
Sat 31 May 2008 - 23:47
Controllo meglio domani, Ciao!
Sun 01 Jun 2008 - 11:45
Basta non cliccare in "Options" sul tasto [Register Filetypes] che associa il software ai file supportati.
Sun 01 Jun 2008 - 12:16
Sun 01 Jun 2008 - 18:07
Registered Member #9
CoolPlayer 219
Link winPenPack
Aggiornamento dalla versione 218 alla 219
Home: -Link-
Direct link: -Link-
[ Edited Sun 01 Jun 2008 - 18:07 ]
