Aggiornamento: CoolPlayer |
| Rcs |
![]() ![]() ![]() ![]() Utente registrato #675 Registrato il: mar 23 gen 2007 - 23:49Provenienza: Salvitelle (Sa) Messaggi: 12717 ![]() | CoolPlayer 218 Link winPenPack Aggiornamento dalla versione 217 alla 218 Home: -Link- ![]() Direct link: -Link- ![]() Risultato test: Scrive le chiavi HKLM\SOFTWARE\Classes | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Rcs ha scritto ... Scrive le chiavi HKLM\SOFTWARE\Classes \Classes... e poi? | ||
| Rcs |
![]() ![]() ![]() ![]() Utente registrato #675 Registrato il: mar 23 gen 2007 - 23:49Provenienza: Salvitelle (Sa) Messaggi: 12717 ![]() | Chiave aggiunta:22 ---------------------------------- HKLM\SOFTWARE\Classes\Folder\shell\CoolPlayer Play HKLM\SOFTWARE\Classes\Folder\shell\CoolPlayer Play\command HKLM\SOFTWARE\Classes\Folder\shell\CoolPlayer Queue HKLM\SOFTWARE\Classes\Folder\shell\CoolPlayer Queue\command HKLM\SOFTWARE\Classes\CoolPlayer.Audio HKLM\SOFTWARE\Classes\CoolPlayer.Audio\DefaultIcon HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell\CoolPlayer Play HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell\CoolPlayer Play\command HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell\CoolPlayer Queue HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell\CoolPlayer Queue\command HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell\Open HKLM\SOFTWARE\Classes\CoolPlayer.Audio\Shell\Open\command HKLM\SOFTWARE\Classes\CoolPlayer.Playlist HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\DefaultIcon HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell\CoolPlayer Play HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell\CoolPlayer Play\command HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell\CoolPlayer Queue HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell\CoolPlayer Queue\command HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell\Open HKLM\SOFTWARE\Classes\CoolPlayer.Playlist\Shell\Open\command | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | Non c'è modo di evitare la scrittura di quelle chiavi? Che so... inserendo il solito file vuoto, o non selezionando alcune opzioni.. | ||
| Rcs |
![]() ![]() ![]() ![]() Utente registrato #675 Registrato il: mar 23 gen 2007 - 23:49Provenienza: Salvitelle (Sa) Messaggi: 12717 ![]() | Controllo meglio domani, Ciao! | ||
| Rcs |
![]() ![]() ![]() ![]() Utente registrato #675 Registrato il: mar 23 gen 2007 - 23:49Provenienza: Salvitelle (Sa) Messaggi: 12717 ![]() | Danix ha scritto ... Non c'è modo di evitare la scrittura di quelle chiavi? Che so... inserendo il solito file vuoto, o non selezionando alcune opzioni.. Basta non cliccare in "Options" sul tasto [Register Filetypes] che associa il software ai file supportati. | ||
![]() ![]() ![]() ![]() Utente registrato #1 Registrato il: ven 29 dic 2006 - 05:38Provenienza: Sassari Messaggi: 12998 ![]() | ![]() | ||
| eagleman |
![]() ![]() Utente registrato #9 Registrato il: sab 20 gen 2007 - 21:36Provenienza: Veglie Messaggi: 2290 ![]() | CoolPlayer 219 Link winPenPack Aggiornamento dalla versione 218 alla 219 Home: -Link- ![]() Direct link: -Link- ![]() [ Modificato dom 01 giu 2008 - 18:07 ] | ||
