[PIM] pAgenda-3.2 OpenSource GPL2 No-Install |
| icemax |
![]() ![]() Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 ![]() | Nome del software: pAgenda-3.2 Direct Link al download: -Link- ![]() Dimensione File: Windows Zipped 8330k Nome autore: 2005-2007 by Paul Sherman Sito Web Autore: -Link- ![]() eMail autore: -eMail- ![]() Descrizione: Agenda/Calendario/ToDo scritto in Python. Usa sqlite come database per gestire shede/utenti Stampa facilitata delle schede giornaliere Import/Export via CSV (comma separated value) files Email links in contacts Portable tips how-to: nessuna - programma portatile Versione:3.2 Licenza: OpenSource GPL2 -------------- altre info ---------------------------- • Programma [TIPO] • NO INSTALL • Nome Eseguibile• PAGENDA.EXE • Linguaggio di Programmazione • Python. • Librerie richieste • nessuna • Versione • Release 3.2 • Dimensione Eseguibile • 126 KB (129.024 byte) • Dimensione Cartella • 15,1 MB (15.841.358 byte) • Portabilità • 100 % [NESSUNA SCRITTURA DATI SU SISTEMA OSPITE] [INFO ORIGINALI] pAgenda is meant to view/edit/print appointments quickly and easily. Separate calendars can be kept for different individuals or various schedules. Cross-Platform Calendar/scheduler written in Python. Uses self-contained sqlite database for multiple users/schedules Has the ability to be copied and run completely from a USB stick. [HowTo originali] When run, pAgenda will ask for a user (schedule) name, and will generate a database in the currently logged-in user's home directory (on Windows, the user's "My Documents.") If you choose to create a database that is viewable by all, then pAgenda will create the database in the folder where pagenda.exe is located. If the user does not have write access to the program directory then the schedule will be opened read-only. [screenshot] ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Inserito in download! ![]() | ||
![]() ![]() ![]() ![]() Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12998 ![]() | Moticanus wrote ... Nome del software: pAgenda-3.2 -Link- ![]() Portable tips how-to: decomprimere il file pAgenda-3.2.zip ed avviare il programma eseguendo PAGENDA.EXE Test effettuato: all'avvio il software chiede di specificare il nome che si vuol assegnare al database. Non mi pare sia però possibile indicare dove salvare il file .db. Infatti:
File aggiunto:1
I database vengono creati nella cartella del programma se al primo avvio, alla domanda "Do you wish to make available the schedule for all users?", si sceglie "Yes". Altrimenti vengono creati nella cartella Documenti del computer. The databases are created in the installation folder if at first run you click "Yes" to the question "Do you wish to make available the schedule for all users?". Otherwise they are created in the Documents folder on your computer. | ||
