[PIM] pAgenda-3.2 OpenSource GPL2 No-Install
icemax
lun 09 apr 2007 - 12:05
Utente registrato #194
Nome del software: pAgenda-3.2
Dimensione File: Windows Zipped 8330k
Nome autore: 2005-2007 by Paul Sherman
eMail autore: -eMail-
Descrizione: Agenda/Calendario/ToDo scritto in Python.
Usa sqlite come database per gestire shede/utenti
Stampa facilitata delle schede giornaliere
Import/Export via CSV (comma separated value) files
Email links in contacts
Portable tips how-to: nessuna - programma portatile
Versione:3.2
Licenza: OpenSource GPL2
-------------- altre info ----------------------------
• Programma [TIPO] • NO INSTALL
• Nome Eseguibile• PAGENDA.EXE
• Linguaggio di Programmazione • Python.
• Librerie richieste • nessuna
• Versione • Release 3.2
• Dimensione Eseguibile • 126 KB (129.024 byte)
• Dimensione Cartella • 15,1 MB (15.841.358 byte)
• Portabilità • 100 % [NESSUNA SCRITTURA DATI SU SISTEMA OSPITE]
[INFO ORIGINALI]
pAgenda is meant to view/edit/print appointments quickly
and easily. Separate calendars can be kept for different
individuals or various schedules.
Cross-Platform Calendar/scheduler written in Python.
Uses self-contained sqlite database for multiple users/schedules
Has the ability to be copied and run completely from a USB stick.
[HowTo originali]
When run, pAgenda will ask for a user (schedule) name,
and will generate a database in the currently logged-in
user's home directory (on Windows, the user's "My Documents.")
If you choose to create a database that is viewable by all,
then pAgenda will create the database in the folder where
pagenda.exe is located. If the user does not have write
access to the program directory then the schedule will be
opened read-only.
[screenshot]
mer 11 apr 2007 - 22:41
Inserito in download!
dom 25 apr 2010 - 18:12
Moticanus ha scritto ...
Nome del software: pAgenda-3.2 -Link-
Portable tips how-to: decomprimere il file pAgenda-3.2.zip ed avviare il programma eseguendo PAGENDA.EXE
Test effettuato: all'avvio il software chiede di specificare il nome che si vuol assegnare al database. Non mi pare sia però possibile indicare dove salvare il file .db. Infatti:
File aggiunto:1
C:\Documents and Settings\home_virtual\Documenti\_prova.db
I database vengono creati nella cartella del programma se al primo avvio, alla domanda "Do you wish to make available the schedule for all users?", si sceglie "Yes". Altrimenti vengono creati nella cartella Documenti del computer.
The databases are created in the installation folder if at first run you click "Yes" to the question "Do you wish to make available the schedule for all users?". Otherwise they are created in the Documents folder on your computer.
