Aggiornamento: X-SweetHome3D
Go to page   <<
Wed 15 Jan 2014 - 15:39
Registered Member #675
X-Sweet Home 3D 4.3
Link winPenPack
Aggiornamento dalla versione 4.2 alla 4.3
Home: -Link-
Direct Link: -Link-
--- edit zandet2 ---
software wpp aggiornato
[ Edited Tue 29 Apr 2014 - 22:45 ]
Fri 13 Jun 2014 - 14:34
X-Sweet Home 3D 4.4
Link winPenPack
Aggiornamento dalla versione 4.3 alla 4.4
Home: -Link-
Direct Link: -Link-
[ Edited Fri 18 Jul 2014 - 11:24 ]
Sat 25 Oct 2014 - 22:29
X-Sweet Home 3D 4.5
Link winPenPack
Aggiornamento dalla versione 4.4 alla 4.5
Home: -Link-
Direct Link: -Link-
Tue 03 Feb 2015 - 17:11
X-Sweet Home 3D 4.6
Link winPenPack
Aggiornamento dalla versione 4.5 alla 4.6
Home: -Link-
Direct Link: -Link-
Mon 20 Jul 2015 - 21:47
X-Sweet Home 3D 5.0
Link winPenPack
Aggiornamento dalla versione 4.6 alla 5.0
Home: -Link-
Direct Link: -Link-
[ Edited Mon 20 Jul 2015 - 21:50 ]
Sat 21 Nov 2015 - 19:30
X-Sweet Home 3D 5.1
Link winPenPack
Aggiornamento dalla versione 5.0 alla 5.1
Home: -Link-
Direct Link: -Link-
[ Edited Sat 21 Nov 2015 - 19:31 ]
Thu 18 Feb 2016 - 21:09
X-Sweet Home 3D 5.2
Link winPenPack
Aggiornamento dalla versione 5.1 alla 5.2
Home: -Link-
Direct Link: -Link-
rbon
Tue 27 Sep 2016 - 17:54
Registered Member #4134
Rcs wrote ...
X-Sweet Home 3D 5.2
Link winPenPack
Home: -Link-
Direct Link: -Link-
Il link inserito da Rcs si collega alla versione 'install' che si chiama 'SweetHome3D-5.2-windows.exe', ma esiste anche una versione portable (non testata) che dovrebbe rendere più facile l'aggiornamento del programma.
Nella pagina di download di Sweet Home 3D -Link- si dice che:
This 7-zip archive contains Sweet Home 3D applications for 32-bit and 64-bit Windows, Mac OS X, 32-bit and 64-bit Linux, bundled with the Java environments required to execute them.
Once you uncompressed this archive in a given folder (on a hard disk or a USB key), you can move this folder or the USB key where you copied it to use Sweet Home 3D on another computer, without losing software configuration.
La pagina di Sourceforge di download si trova qui -Link- ed il file portable si chiama SweetHome3D-5.2-portable.7z -Link-
@Danix
please update this program
Thu 17 Nov 2016 - 23:17
X-Sweet Home 3D 5.3
Link winPenPack
Aggiornamento dalla versione 5.2 alla 5.3
Home: -Link-
Direct Link: -Link-
Direct Link: -Link-
Mon 06 Feb 2017 - 21:17
X-Sweet Home 3D 5.4
Link winPenPack
Aggiornamento dalla versione 5.3 alla 5.4
Home: -Link-
Direct Link: -Link-
Direct Link: -Link-
Go to page   <<
