Aggiornamento: X-SweetHome3D Go to page << |
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Sweet Home 3D 4.3 Link winPenPack Aggiornamento dalla versione 4.2 alla 4.3 Home: -Link- Direct Link: -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Tue 29 Apr 2014 - 22:45 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Sweet Home 3D 4.4 Link winPenPack Aggiornamento dalla versione 4.3 alla 4.4 Home: -Link- Direct Link: -Link- --- edit zandet2 --- software wpp aggiornato [ Edited Fri 18 Jul 2014 - 11:24 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Sweet Home 3D 4.5 Link winPenPack Aggiornamento dalla versione 4.4 alla 4.5 Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Sweet Home 3D 4.6 Link winPenPack Aggiornamento dalla versione 4.5 alla 4.6 Home: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Sweet Home 3D 5.0 Link winPenPack Aggiornamento dalla versione 4.6 alla 5.0 Home: -Link- Direct Link: -Link- [ Edited Mon 20 Jul 2015 - 21:50 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Sweet Home 3D 5.1 Link winPenPack Aggiornamento dalla versione 5.0 alla 5.1 Home: -Link- Direct Link: -Link- [ Edited Sat 21 Nov 2015 - 19:31 ] | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Sweet Home 3D 5.2 Link winPenPack Aggiornamento dalla versione 5.1 alla 5.2 Home: -Link- Direct Link: -Link- | ||
rbon |
Registered Member #4134 Joined: Sat 14 Apr 2007 - 11:42Posts: 911 | Rcs wrote ... X-Sweet Home 3D 5.2 Link winPenPack Aggiornamento dalla versione 5.1 alla 5.2 Home: -Link- Direct Link: -Link- Il link inserito da Rcs si collega alla versione 'install' che si chiama 'SweetHome3D-5.2-windows.exe', ma esiste anche una versione portable (non testata) che dovrebbe rendere più facile l'aggiornamento del programma. Nella pagina di download di Sweet Home 3D -Link- si dice che: This 7-zip archive contains Sweet Home 3D applications for 32-bit and 64-bit Windows, Mac OS X, 32-bit and 64-bit Linux, bundled with the Java environments required to execute them. Once you uncompressed this archive in a given folder (on a hard disk or a USB key), you can move this folder or the USB key where you copied it to use Sweet Home 3D on another computer, without losing software configuration. La pagina di Sourceforge di download si trova qui -Link- ed il file portable si chiama SweetHome3D-5.2-portable.7z -Link- @Danix please update this program | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Sweet Home 3D 5.3 Link winPenPack Aggiornamento dalla versione 5.2 alla 5.3 Home: -Link- Direct Link: -Link- Direct Link: -Link- | ||
Registered Member #675 Joined: Tue 23 Jan 2007 - 23:49Location: Salvitelle (Sa) Posts: 12717 | X-Sweet Home 3D 5.4 Link winPenPack Aggiornamento dalla versione 5.3 alla 5.4 Home: -Link- Direct Link: -Link- Direct Link: -Link- | ||
Go to page <<
