SkyIDE Ide
icemax
Sun 15 Apr 2007 - 12:03
Registered Member #194
Novità per questo fantastico software
SkyIDE beta 12 su -Link-
Discussione originale :
questi gli aggiornamenti :
Release Notes: SkyIDE Beta 12 - Reloaded - Sunday 1 April 2007
Added: Project Propertites next to the new Project Exlorer
Added: Import Foreign Project - converts almost any non-SkyIDE project to a SkyiDE project
Added: Brand new Favorites and History panes. Completely re-written
Added: Move To The Recycle Bin” on Tab->Right Click popup menu.
Added: Bookmaking a line now highlights the whole line instead of putting a dot
Added: Deleting files/folders from project now are all moved to the Recycle Bin
Added: Set #include directory in SkyIDE->Options. Used when searching for header files in “Find Function Declaration” Added: Set Source directory in SkyIDE->Options. Used when searching for source files in “Open/Show Source File”
Added: The project directory text fields in “New Project” dialog are set by default to the project directory set in the SkyIDE->Options.Added: Add New Folder dialog (as part of the new project manager)
Added: Explore your project folders in a Tree View-like styleAdded: Project Explorer has a second tab that lets you view/set some project settings (Preliminary feature)
Added: Customized “Browse for Folder” dialog when seleting project folders - big plans with this one
Added: Self Repairing Projects function if corrupted project is found - (preliminary work)
Fixed: Sometimes when changing compiler profile names, projects no longer compiled
Fixed: Some minor bugs in SkyIDE->Compiler PRofiles dialog box
Fixed: When you search via F3/F4, SkyIDE sometimes would freeze. This error has been fixed.
Fixed: When you rename a project, the project's folder also gets renamed
Fixed: Fixed bugs with “for” loop detection
Fixed: Access Violation bug fixed sometimes when closing tabs
Fixed: Comments bug fixed /* int statements_like_this_in_a_comment_like_this */ got detected
Fixed: A few start up bugs fixed
Improved: The Object Viwer no longer forgets which tab was active when switching between open files
Improved: The SkyIDE->Compilers dialog box. Re-arranged some buttons to make more sense
Improved: Adjusted the left margin of the editor
Improved: A few touch ups on the GUI - more polished
Improved: The Add New Project File dialog (as part of the new project manager)
Improved: “Find Function declaration” re-written. It should work much better if you set the #include dir in SkyIDE->Options
Improved: “Open / Show Main File” and “Open / Show Header File” again if you set the source dir in SkyIDE->Options
Improved: Re-organised the right click menu of the editor
Improved: The Project Menu has been re-arranged
Improved: The right click project popup menu also has been improved. Much cleaner!
Improved: History an Favorites are now in one tab
Sun 15 Apr 2007 - 12:26
Grazie icemax, aggiorno nella sezione download
Tue 17 Mar 2009 - 02:58
Registered Member #5089
Il programma è stato rimosso dal database, motivo -Link-
[ Edited Tue 17 Mar 2009 - 03:38 ]
