AIUTO AVAST RILEVA TROJAN!!! Go to page << >> |
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | No, intendo questo: Avast rileva i virus, tu hai riportato i nomi dei virus, ma non i file all'interno di winPenPack che vengono segnalati come virus. | ||
axel77 |
Registered Member #14433 Joined: Sat 18 Oct 2008 - 13:25Posts: 11 | posso dirti che all'interno delle proprietà del file c'è scritto che viene rilevato in "e mule" ma non riesco a trovare altri dati utili!!! | ||
axel77 |
Registered Member #14433 Joined: Sat 18 Oct 2008 - 13:25Posts: 11 | E:\winPenPack 3.4 - Flash 1Gb\winPenPack\Bin\eMule\is-CNVRF.tmp [L] Win32:Trojan-gen {Other} (0) File spostato con successo nel cestino... E:\winPenPack 3.4 - Flash 1Gb\winPenPack\Bin\eMule\is-U30C7.tmp [L] Win32:Trojan-gen {Other} (0) File spostato con successo nel cestino... E:\winPenPack 3.4 - Flash 1Gb\winPenPack\Bin\eMule\is-39BK9.tmp [L] Win32:Trojan-gen {Other} (0) File spostato con successo nel cestino... E:\winPenPack 3.4 - Flash 1Gb\winPenPack\Bin\eMule\is-39BK9.tmp [L] Win32:Trojan-gen {Other} (0) * | ||
axel77 |
Registered Member #14433 Joined: Sat 18 Oct 2008 - 13:25Posts: 11 | file. 18/10/2008 19.32.50 1224351170 ALESSIO E CHIARA 1620 Sign of "Win32:Trojan-gen {Other}" has been found in "E:\winPenPack 3.4 - Flash 1Gb\winPenPack\Bin\eMule\is-U30C7.tmp" file. 18/10/2008 20.27.53 1224354473 ALESSIO E CHIARA 1620 Sign of "Win32:Trojan-gen {Other}" has been found in "E:\winPenPack 3.4 - Flash 1Gb\winPenPack\Bin\eMule\is-39BK9.tmp" file. 18/10/2008 23.35.54 1224365754 ALESSIO E CHIARA 1620 Sign of "Win32:Trojan-gen {Other}" has been found in "E:\winPenPack 3.4 - Flash 1Gb\winPenPack\Bin\eMule\is-39BK9.tmp" file. 18/10/2008 23.38.12 1224365892 ALESSIO E CHIARA 3196 Sign of "Win32:Trojan-gen {Other}" has been found in "E:\winPenPack 3.4 - Flash 1Gb\winPenPack\Bin\eMule\is-U30C7.tmp" file. 18/10/2008 23.38.30 1224365910 ALESSIO E CHIARA 3756 Sign of "Win32:Trojan-gen {Other}" has been found in "E:\winPenPack 3.4 - Flash 1Gb\winPenPack\Bin\eMule\is-39BK9.tmp" file. 18/10/2008 23.38.33 1224365913 ALESSIO E CHIARA 3756 Sign of "Win32:Trojan-gen {Other}" has been found in "E:\winPenPack 3.4 - Flash 1Gb\winPenPack\Bin\eMule\is-CNVRF.tmp" file. 18/10/2008 23.38.35 1224365915 ALESSIO E CHIARA 3756 Sign of "Win32:Trojan-gen {Other}" has been found in "E:\winPenPack 3.4 - Flash 1Gb\winPenPack\Bin\eMule\is-U30C7.tmp" file. 18/10/2008 23.50.23 1224366623 ALESSIO E CHIARA 3472 Sign of "Win32:Trojan-gen {Other}" has been found in "E:\wpp_1gb_3.4.exe\{app}\winPenPack\Bin\eMule\emule.exe" file. 18/10/2008 23.50.52 1224366652 ALESSIO E CHIARA 3472 Sign of "Win32:AutoRun-AMF [Wrm]" has been found in "E:\wpp_1gb_3.4.exe\{app}\winPenPack\Bin\JKDefragTWGUI\JKDefragTWGUI.exe" file. 18/10/2008 23.54.32 1224366872 ALESSIO E CHIARA 3472 Sign of "Win32:Trojan-gen {Other}" has been found in "E:\wpp_1gb_3.4.exe\{app}\winPenPack\Bin\wpp_pampa\PAMPA\REGCLEAR.exe" file. | ||
axel77 |
Registered Member #14433 Joined: Sat 18 Oct 2008 - 13:25Posts: 11 | 19/10/2008 1.05.25 1224371125 ALESSIO E CHIARA 716 Sign of "Win32:Trojan-gen {Other}" has been found in "E:\wpp_essential_3.4.zip\winPenPack\Bin\eMule\emule.exe" file. | ||
axel77 |
Registered Member #14433 Joined: Sat 18 Oct 2008 - 13:25Posts: 11 | basta tutta sta roba???questo e tutto quello che ho trovato!!! | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Ok, riguardano emule, REGCLEAR.exe e JKDefragTWGUI.exe Tutti falsi positivi (quindi non ti devi preoccupare), come già detto da zandet2. Quindi, senza allarmismi inutili leggi e segui queste indicazioni. | ||
axel77 |
Registered Member #14433 Joined: Sat 18 Oct 2008 - 13:25Posts: 11 | grazie danix!! volevo chiederti un ultima cosa io come ho scritto sopra ho scansionato su virustotal, parecchi antivirus rilevano infetti i file!! ma se tu mi dici che è tutto ok!! io procedo con l'installazione..... scusa se ti ho fatto perdere tempo sono nuovo iscritto e nuovo per quanto riguarda i programmi x chiavetta!!! ti ringrazio ancora x l'aiuto!!! ciao | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Tranquillo, al massimo esplode il pc Buona permanenza su winPenPack. | ||
rizlapiu |
Registered Member #15675 Joined: Sun 07 Dec 2008 - 21:41Posts: 1 | salve.... ho provato tutti i pacchetti certo è stato un lavoraccio per voi riunire tutti questi virus in pochi gb GRAZZIE~:( | ||
