[MASTERING] Collection di programmi PORTATILI gratuiti [THE MUST] Go to page >> |
icemax |
Registered Member #194 Joined: Sun 21 Jan 2007 - 22:27Posts: 1371 | Oggi carrellata di prodotti affidabili e gratuiti per : - masterizzazione - ripping - Immagini ISO ... a voi i commenti Nome del software: Easy Burning 2.03 Direct Link al download: -Link- Dimensione File: 1114.16 KB Nome autore: Dirk Paehl Sito Web Autore: -Link- eMail autore:n.d Descrizione: Easy Burning è un semplice programma gratuito per masterizzare qualsiasi tipo di dati su CD e DVD. Permette inoltre di cancellare i riscrivibili supporta la multisessione, ha funzioni di comparazione cartelle e controllo file, riconoscimento indipendente ASPI/SPTI interno, verifica file dopo la scrittura Portable tips how-to: Estrarre il file setup.exe con universal extractor, Easy Burning 2.03 diverrà Totalmente PORTATILE Versione:2.03 Licenza:Freeware screenshot : descrizione originale This program is freeware.EASY Burning is the easiest way to backup your files in a cdr(w). Integrated to the shell (send to) or used as a normal application, EASY Burning works with any CD writer. Write a folder and files, pictures and what ever you want. Easy to use. Create Data CD from a folder. Backup your MP3 collection. Integrated into Shell. send to Integrated into Desktop, Can write CD/DVD in the UDF format. Designed for Windows 98, Me, 2000, XP. Multissession, Multifolder, Multifile(s) support. Incl. Folder compare and Check-File. This program have an independant internal ASPI/SPTI detection. Multilanguage file (english, german, french, finnish, spanish, danish, portuguese, hungarian, galician, macedonian, polish, catalan, italian, russian, japanese, nederlands, ukrainian, SimpChinese, korean, chinese_taiwan, serbian, Serbian ASCII, Serbian cyryllic, Serbian latin), turkish, Brazilian Portuguese and swedish. Inclusive VisualISO for multi file and folder. Now include Verify file after burn. Burn Video DVD (DVD Version only) All language file as extra download.. -Link- ================================================================== Nome del software: Folder CD/DVD Burn Direct Link al download: -Link- Dimensione File: 624 KB (639.749 byte) Nome autore: nd Sito Web Autore: -Link- eMail autore: nd Descrizione: Folder CD/DVD Burner è un programma freeware che vi consente di masterizzare i file su CD o DVD a partire dalle cartelle. Non possono essere inseriti i singoli file. Per tradurre il programma scaricate la patch da qui -Link- ed estraete TUTTA la cartella contenuta nell'archivio nella cartella languages del programma. Non estraete solo il file contenuto nella cartella dentro l'archivio Portable tips how-to: Estrarre il file setup.exe con universal extractor Versione: 1.0 Licenza: freeware screenshot : forum : -Link- ================================================================== Nome del software: BURNISO version 1.05 Direct Link al download: -Link- Dimensione File: 785kb Nome autore: nd Sito Web Autore: .. eMail autore: .. Descrizione: è un software dalla semplicità disarmante e permette, in pochi di click, di "bruciare" immagini Iso e cancellare cd riscrivibili Portable tips how-to: decomprimere il file. Versione: 1.05 PORTATILE Licenza: freeware screenshot : info originali : Include the cdrecord 2.01.01a23 with original DVD support Burn standard ISO and CUE/BIN VCD and SVCD with overburn support. Support DVD_RW_FORMAT ================================================================== Nome del software: Visual-ISO 1.1 Beta 8 Direct Link al download: -Link- Dimensione File: 271.03 KB Nome autore: Dirk Paehl Sito Web Autore: -Link- eMail autore: nd Descrizione: Questo programma ci permetterà di creare delle immagini .Iso con i dati che ci servono sull'hard-disk per poi masterizzarle in un secondo tempo Portable tips how-to: portatile Versione: 1.1 Beta 8 Licenza: freeware screenshot : info originali : Visual-ISO is (c) by Dirk Paehl as freeware You can use this Visual-ISO with Easyburning. Replace the VisualIso.exe only Or use it as standalone program. This program supported Drag&Drop too. Visual-ISO helps you to create a mkisofs path-file. Usage: "mkisofs -J -o target_file.iso -path-list your_visual_iso_generated_file.txt -graft-points". Or use the Make ISO button. The result is a standard ISO file. Direct on the fly burn to CD/DVD (ON W2K or higher only) ================================================================== Nome del software: Databurning 1.0 beta 48 Direct Link al download: -Link- Dimensione File: 1665 KB Nome autore: Dirk Paehl Sito Web Autore: -Link- eMail autore: .. Descrizione: This program use the CDRTOOLS for burning CD and DVD incl DVD-RAM support Portable tips how-to: Decomprimere il file Setup.exe con universal extractor Versione:1.0 beta 48 Licenza: free screenshot : info originali : This program use the CDRTOOLS for burning CD and DVD incl DVD-RAM support. You can burn your data directly on the FLY or later via batchfile. Include Verify after burn. This program does not run under Win9x, only W2K / XP or higher. Burn ISO and verify and burn CUE/BIN Or you can create a mkisofs path-file or commandline use the cdrtools. Include the original CDRTOOLS 2.01a25 with DVD / DL and DVD-RAM support With PRODVD support (NO MORE NEEDED). ================================================================== Nome del software: CD DVD to ISO 1.0 Direct Link al download: -Link- Dimensione File: 320 KB (327.680 byte) Nome autore: -Link- Sito Web Autore: -Link- eMail autore: nd Descrizione: Convertye in immagine iso il contenuto di un DVD/cd Portable tips how-to: portatile Versione: 1.0 Licenza: freeware screenshot : info originali : This program use readcd from the CDRTOOLS (c) by Jörg Schilling. readcd version 2.01 final include. With this program you can make an ISO from your CD or DVD. Sample if you have read problems with the medium. This program have an own ASPI/SPTI detection include. Supported all Windows version, (NO WIN 3.x) ================================================================== Nome del software: CD EasyBurning 0.2 beta Direct Link al download: -Link- Dimensione File: 671.24 KB Nome autore: nd Sito Web Autore: -Link- eMail autore: .. Descrizione: un piccolissimo (e semplice) programma in grado di masterizzare su CDrom dati , musica , ecc. La grafica è un po spartana ma è normale per un programma così piccolo che pu? stare persino in un floppy Portable tips how-to: decomprimere il file Versione: 0.2 beta Licenza: freeware screenshot : info originali : This program is freeware. Use the cdrtools from Joerg Schilling. CD EasyBurning can be run from a CDROM, eg. Windows PE. No installation required, no write in the registry or on a device, except VisualISO. (c) by Dirk Paehl -Link- If you want use a full EasyBurning visit my site, or if you found a bug write it in my forum: -Link- This program is tested under Win W2K/XP and 98. If you want use this under Win9x you must download from my site easyburn_98.zip . ================================================================== Nome del software: Folder to ISO Win Direct Link al download: -Link- Dimensione File: 868 Kb Nome autore: paehl Sito Web Autore: -Link- eMail autore: .. Descrizione: E' un programma di semplicità estrema, che permette di creare un file ISO da una cartella. Sembrerebbe una funzione inutile, tuttavia in questo modo è possibile scrivere DVD Video partendo da una cartella VIDEO_TS con qualsiasi programma di masterizzazione, anche quelli che non supportano la scrittura di DVD Video (questa funzione ha anche altri utilizzi, come quelli impiegati nella mia guida per creare divx dai DVD). Portable tips how-to: portatile Versione: 1.0 Licenza: freeware screenshot : info originali : This program use MKISOFS for making an ISO from a folder incl all subfolders. Windows and Linux Version available. ================================================================== Nome del software: AUDIO CD 0.12 Direct Link al download: -Link- Dimensione File: 1025.82 KB Nome autore: Dirk Paehl Sito Web Autore: -Link- eMail autore: .. Descrizione: Permette di "rippare" tracce audio di un cd/dvd in formato WAV/CDR-RAW/AU/AIF/AIFC Portable tips how-to: Decomprimere il file Setup.exe con universal extractor Versione: 0.12 Licenza: freeware screenshot : info originali : This program use the CDRTOOLS. You can rip a audio cd to WAV/CDR-RAW/AU/AIF/AIFC. You can select the output quality from Mono 8bit till maximum. All tracks rip or select from 1-x. You can burn WAV/CDR/AU audio files to CD. CUE-Sheet open and burn. Support CD-TEXT and CDDB. Output all Audio CD-Infos. You can erase RW fast or normal. This program have an internal independant ASPI/SPTI detection. Normal this program identify all burner.No ASPI driver required for NT/W2K or XP.Multilanguage in this version: english/german/french/catalan/italian/russian ================================================================================ Nome del software: CDDVD COPY 1.4 Direct Link al download: -Link- Dimensione File: 972.49 KB Nome autore: Dirk Paehl Sito Web Autore: -Link- eMail autore: nd Descrizione: copia diretta 1:1 tra 2 unità ottiche CD/DVD Portable tips how-to: Decomprimere il file Setup.exe con universal extractor Versione: 1.4 Licenza: freeware screenshot : info originali : CDDVD COPY incl. CDR-TOOLS v2.01.01a11 (CD and DVD version) This program is an an to use CD/DVD COPY Use the CDRTOOLS from Jörg Schilling. With this program you can copy your CD or DVD very easy. You can erase CD-RW or DVD. Support: OVERBURN. Create and ISO from CD/DVD. Multilanguage (English,German, French, Catalan,Czech, Hungarian, Italian, Slovak, Spanish, portuguese PT). FREEWARE. This GUI have an own ASPI/SPTI detection. No ASPI driver required for NT/W2K or XP. e per finire : Nome del software: CONVERT2ISO 0.1 Direct Link al download: -Link- Dimensione File: 31.91 KB Nome autore: Dirk Paehl Sito Web Autore: -Link- eMail autore: Descrizione: Convert2ISO convert a NERO NRG Image and a BIN (e.g CDRWIN) BIN to a standard ISO file And create a cuefile from a BIN image. Portable tips how-to: portatile Versione: 0.1 Licenza: free screenshot : spero di avervi fatto felici ciaoooooooooo [ Edited Thu 26 Apr 2007 - 09:28 ] | ||
RADIOZETA |
Registered Member #1056 Joined: Thu 25 Jan 2007 - 22:53Posts: 6 | Carissimo IceMax in relazione all'ottima carrellata di software per la masterizzazione e non solo potrei chiederti se conosci un programma portable per la stampa delle cover di DVD e CD da includere a questa collection? Ti ringrazio anticipatamente Ciao | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | Ciao Radiozeta, Finora avevamo DeepBurner Portable, ma poi Danix ha scoperto che non era poi così portatile... Per il momento ho trovato solamente Label XPress (che trovi qui: -Link- ). Non è bellissimo, ma almeno, non avendo opzioni (!), non scrive nulla sul sistema ospite. Fra gli altri, posso segnalarti UnderCoverXP (che trovi qui: -Link- ), che, pur non essendo portatile in maniera nativa, scrive però tutti i suoi settaggi sotto questa unica voce di registro:
[HKEY_USERS\S-1-5-21-698813702-420252843-2910830495-1131\Software\Wicked & Wild Inc.]
quindi potrebbe, eventualmente, essere reso portatile attraverso un X-Launcher. N.B. Si può evitare di installarlo: basta estrarlo con Universal Extractor. Cordialmente ZioZione P.S. Danix, chiedo scusa per la becera segnalazione e per averti "messo in mezzo"... Vedi tu se e cosa puoi fare... e soprattutto se ritieni che ne valga la pena... | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Innanzitutto una precisazione: RADIOZETA, se avessi postato la tua richiesta nella sezione apposita del forum, avresti dato la possibilità ad altri di usufruire di queste informazioni in modo facile e veloce. In questo modo, postando in coda a un messaggio di altro tipo (quindi Off Topic) si crea disordine. Pertanto ti pregherei di fare più attenzione per le prossime volte. Grazie. ---------------------------------------------------------------------- Detto questo... UnderCoverXP si può rendere portatile. Istruzioni: 1 - Scaricare X-Launcher da qui link: -Link- 2 - eliminare tutto il codice inserito in X-Launcher_Example.ini e copiare questo:
3 - rinominare X-Launcher_Example.ini in X-Launcher.ini 4 - inserire l'applicazione (i files estratti con Universal Extractor o la cartella di installazione) in una cartella chiamata "UnderCoverXP" che va inserita a sua volta in \Bin 5 - lanciare X-Launcher.exe per avviare l'applicazione 6 - da questo momento tutte le impostazioni saranno scritte nella cartella \User [ Edited Thu 26 Apr 2007 - 14:28 ] | ||
forart.eu |
Registered Member #4745 Joined: Fri 18 May 2007 - 11:50Posts: 16 | RADIOZETA wrote ... potrei chiederti se conosci un programma portable per la stampa delle cover di DVD e CD da includere a questa collection? Dunque, ho fatto un po' di search ed effettivamente sw di labeling opn per windows non ce ne sono... pero: Dialog CD Writer (GPL) di Umberto Galtarossa CD/DVD Inserts and Envelopes CDox ma è in Java... ...insomma un sw open decente per stampare CD/DVD e relative copertine. Sarebbe carino lanciare un progetto per "metterne insieme" uno (un po' alla WinLibre che con la sua partecipazione al SoC ha "creato" infrarecorder) Al momento si potrebbe pensare di sfruttare questi templates | ||
forart.eu |
Registered Member #4745 Joined: Fri 18 May 2007 - 11:50Posts: 16 | Cerca cerca, alla fine qualcosa viene fuori: CD Cover di Carlo Beggiato Sembrerebbe un buon punto di partenza... | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Ottimo e .... quasi portatile! Con X-Launcher e questo INI è quasi perfetto (ma non rileva i dati del supporto di masterizzazione):
[ Edited Sat 19 May 2007 - 20:51 ] | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | a me con questo ini mi ritorna anche il seguente errore: "error loading MIDAS.DLL" lo risolvo se metto "midas.dll" nella cartella con x-launcher. ma non ho capito perchè fa questa chiamata! | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3357 | RISOLTO: Siccome avevo fatto l'installazione di CDCOVER, quest'ultima aveva scritto 5 voci nel registry che richiamavano la dll con la path originale del programma. Una volta rimosse "a mano" ho risolto il problema. Ora verifico se le ha riscritte.... [EDIT BY TAF] Si, le voci vengono ricreate nel registry!! in questa posizione (e succesive 4 repliche) HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9E8D2FA1-591C-11D0-BF52-0020AF32BD64} e fanno capo a: Borland Midas DSBase 1 [ Edited Mon 21 May 2007 - 11:19 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Si purtroppo bisogna registrare la dll.. -Link- Anche esportando le chiavi da te indicate, non si risolve:
[ Edited Mon 21 May 2007 - 12:18 ] | ||
