[MASTERING] Collection di programmi PORTATILI gratuiti [THE MUST]
icemax
Thu 26 Apr 2007 - 09:22
Registered Member #194
Oggi carrellata di prodotti affidabili e gratuiti per :
- masterizzazione
- ripping
- Immagini ISO
... a voi i commenti
Nome del software: Easy Burning 2.03
Dimensione File: 1114.16 KB
Nome autore: Dirk Paehl
eMail autore:n.d
Descrizione: Easy Burning è un semplice programma gratuito per masterizzare
qualsiasi tipo di dati su CD e DVD. Permette inoltre di cancellare i riscrivibili
supporta la multisessione, ha funzioni di comparazione cartelle e controllo file,
riconoscimento indipendente ASPI/SPTI interno, verifica file dopo la scrittura
Portable tips how-to: Estrarre il file setup.exe con universal extractor,
Easy Burning 2.03 diverrà Totalmente PORTATILE
Versione:2.03
Licenza:Freeware
screenshot :
descrizione originale
This program is freeware.EASY Burning is the easiest way to backup your files in a cdr(w). Integrated to the shell (send to) or used as a normal application, EASY Burning works with any CD writer. Write a folder and files, pictures and what ever you want. Easy to use. Create Data CD from a folder. Backup your MP3 collection. Integrated into Shell. send to Integrated into Desktop, Can write CD/DVD in the UDF format. Designed for Windows 98, Me, 2000, XP. Multissession, Multifolder, Multifile(s) support. Incl. Folder compare and Check-File. This program have an independant internal ASPI/SPTI detection. Multilanguage file (english, german, french, finnish, spanish, danish, portuguese, hungarian, galician, macedonian, polish, catalan, italian, russian, japanese, nederlands, ukrainian, SimpChinese, korean, chinese_taiwan, serbian, Serbian ASCII, Serbian cyryllic, Serbian latin), turkish, Brazilian Portuguese and swedish. Inclusive VisualISO for multi file and folder. Now include Verify file after burn. Burn Video DVD (DVD Version only)
All language file as extra download.. -Link-
Nome del software: Folder CD/DVD Burn
Dimensione File: 624 KB (639.749 byte)
Nome autore: nd
eMail autore: nd
Descrizione: Folder CD/DVD Burner è un programma freeware che vi consente di masterizzare
i file su CD o DVD a partire dalle cartelle.
Non possono essere inseriti i singoli file.
Per tradurre il programma scaricate la patch da qui -Link- ed estraete TUTTA la cartella contenuta nell'archivio nella cartella languages del programma. Non estraete solo il file contenuto nella cartella dentro l'archivio
Versione: 1.0
Licenza: freeware
screenshot :
forum :
Nome del software: BURNISO version 1.05
Dimensione File: 785kb
Nome autore: nd
Sito Web Autore: ..
eMail autore: ..
Descrizione: è un software dalla semplicità disarmante e permette, in pochi di click, di
"bruciare" immagini Iso e cancellare cd riscrivibili
Portable tips how-to: decomprimere il file.
Versione: 1.05 PORTATILE
Licenza: freeware
screenshot :
info originali :
Include the cdrecord 2.01.01a23 with original DVD support
Burn standard ISO and CUE/BIN VCD and SVCD
with overburn support. Support DVD_RW_FORMAT
Nome del software: Visual-ISO 1.1 Beta 8
Dimensione File: 271.03 KB
eMail autore: nd
Descrizione: Questo programma ci permetterà di creare delle immagini .Iso con i dati che
ci servono sull'hard-disk per poi masterizzarle in un secondo tempo
Portable tips how-to: portatile
Versione: 1.1 Beta 8
Licenza: freeware
screenshot :
info originali :
Visual-ISO is (c) by Dirk Paehl as freeware You can use this Visual-ISO with Easyburning. Replace the VisualIso.exe only Or use it as standalone program. This program supported Drag&Drop too. Visual-ISO helps you to create a mkisofs path-file. Usage: "mkisofs -J -o target_file.iso -path-list your_visual_iso_generated_file.txt -graft-points". Or use the Make ISO button. The result is a standard ISO file. Direct on the fly burn to CD/DVD (ON W2K or higher only)
Nome del software: Databurning 1.0 beta 48
Dimensione File: 1665 KB
eMail autore: ..
Descrizione: This program use the CDRTOOLS for burning CD and DVD incl DVD-RAM support
Portable tips how-to: Decomprimere il file Setup.exe con universal extractor
Versione:1.0 beta 48
Licenza: free
screenshot :
info originali :
This program use the CDRTOOLS for burning CD and DVD incl DVD-RAM support.
You can burn your data directly on the FLY or later via batchfile. Include Verify after burn. This program does not run under Win9x, only W2K / XP or higher.
Burn ISO and verify and burn CUE/BIN
Or you can create a mkisofs path-file or commandline use the cdrtools. Include the original CDRTOOLS 2.01a25 with DVD / DL and DVD-RAM support
With PRODVD support (NO MORE NEEDED).
Nome del software: CD DVD to ISO 1.0
Dimensione File: 320 KB (327.680 byte)
Nome autore: -Link-
eMail autore: nd
Descrizione: Convertye in immagine iso il contenuto di un DVD/cd
Versione: 1.0
Licenza: freeware
screenshot :
info originali :
This program use readcd from the CDRTOOLS (c) by Jörg Schilling.
readcd version 2.01 final include. With this program you can make an ISO from your CD or DVD.
Sample if you have read problems with the medium.
This program have an own ASPI/SPTI detection include.
Supported all Windows version, (NO WIN 3.x)
Nome del software: CD EasyBurning 0.2 beta
Dimensione File: 671.24 KB
Nome autore: nd
eMail autore: ..
Descrizione: un piccolissimo (e semplice) programma in grado di masterizzare su CDrom
dati , musica , ecc. La grafica è un po spartana ma è normale per un programma così
piccolo che pu? stare persino in un floppy
Versione: 0.2 beta
Licenza: freeware
screenshot :
info originali :
This program is freeware. Use the cdrtools
from Joerg Schilling. CD EasyBurning can be
run from a CDROM, eg. Windows PE. No
installation required, no write in the registry
or on a device, except VisualISO.
(c) by Dirk Paehl -Link-
If you want use a full EasyBurning visit my
site, or if you found a bug write it in my
forum: -Link-
This program is tested under Win W2K/XP and 98.
If you want use this under Win9x you must download
from my site easyburn_98.zip .
Nome del software: Folder to ISO Win
Dimensione File: 868 Kb
Nome autore: paehl
eMail autore: ..
Descrizione: E' un programma di semplicità estrema, che permette di creare un file ISO da
una cartella. Sembrerebbe una funzione inutile, tuttavia in questo modo è possibile
scrivere DVD Video partendo da una cartella VIDEO_TS con qualsiasi programma di
masterizzazione, anche quelli che non supportano la scrittura di DVD Video (questa
funzione ha anche altri utilizzi, come quelli impiegati nella mia guida per creare divx
dai DVD).
Versione: 1.0
Licenza: freeware
screenshot :
info originali :
This program use MKISOFS for making an ISO from a folder incl all subfolders. Windows and Linux Version available.
Nome del software: AUDIO CD 0.12
Dimensione File: 1025.82 KB
eMail autore: ..
Descrizione: Permette di "rippare" tracce audio di un cd/dvd in formato WAV/CDR-RAW/AU/AIF/AIFC
Versione: 0.12
Licenza: freeware
screenshot :
info originali :
This program use the CDRTOOLS. You can rip a audio cd to WAV/CDR-RAW/AU/AIF/AIFC. You can select the output quality from Mono 8bit till maximum. All tracks rip or select from 1-x. You can burn WAV/CDR/AU audio files to CD. CUE-Sheet open and burn. Support CD-TEXT and CDDB. Output all Audio CD-Infos. You can erase RW fast or normal. This program have an internal independant ASPI/SPTI detection. Normal this program identify all burner.No ASPI driver required for NT/W2K or XP.Multilanguage in this version: english/german/french/catalan/italian/russian
Nome del software: CDDVD COPY 1.4
Dimensione File: 972.49 KB
eMail autore: nd
Descrizione: copia diretta 1:1 tra 2 unità ottiche CD/DVD
Versione: 1.4
Licenza: freeware
screenshot :
info originali :
CDDVD COPY incl. CDR-TOOLS v2.01.01a11 (CD and DVD version)
This program is an an to use CD/DVD COPY Use the CDRTOOLS from Jörg Schilling.
With this program you can copy your CD or DVD very easy. You can erase CD-RW or DVD. Support: OVERBURN. Create and ISO from CD/DVD. Multilanguage (English,German, French, Catalan,Czech, Hungarian, Italian, Slovak, Spanish, portuguese PT). FREEWARE. This GUI have an own ASPI/SPTI detection. No ASPI driver required for NT/W2K or XP.
e per finire :
Nome del software: CONVERT2ISO 0.1
Dimensione File: 31.91 KB
eMail autore:
Descrizione: Convert2ISO convert a NERO NRG Image and a BIN (e.g CDRWIN) BIN to a standard ISO file
And create a cuefile from a BIN image.
Versione: 0.1
Licenza: free
screenshot :
spero di avervi fatto felici
ciaoooooooooo
[ Edited Thu 26 Apr 2007 - 09:28 ]
RADIOZETA
Thu 26 Apr 2007 - 12:29
Registered Member #1056
Carissimo IceMax
in relazione all'ottima carrellata di software per la masterizzazione e non solo potrei chiederti se conosci un programma portable per la stampa delle cover di DVD e CD da includere a questa collection?
Ti ringrazio anticipatamente
Thu 26 Apr 2007 - 14:03
Registered Member #74
Ciao Radiozeta,
Finora avevamo DeepBurner Portable, ma poi Danix ha scoperto che non era poi così portatile...
Per il momento ho trovato solamente Label XPress (che trovi qui: -Link- ). Non è bellissimo, ma almeno, non avendo opzioni (!), non scrive nulla sul sistema ospite.
Fra gli altri, posso segnalarti UnderCoverXP (che trovi qui: -Link- ), che, pur non essendo portatile in maniera nativa, scrive però tutti i suoi settaggi sotto questa unica voce di registro:
[HKEY_USERS\S-1-5-21-698813702-420252843-2910830495-1131\Software\Wicked & Wild Inc.]
quindi potrebbe, eventualmente, essere reso portatile attraverso un X-Launcher. N.B. Si può evitare di installarlo: basta estrarlo con Universal Extractor.
P.S. Danix, chiedo scusa per la becera segnalazione e per averti "messo in mezzo"... Vedi tu se e cosa puoi fare... e soprattutto se ritieni che ne valga la pena...
Thu 26 Apr 2007 - 14:17
Innanzitutto una precisazione: RADIOZETA, se avessi postato la tua richiesta nella sezione apposita del forum, avresti dato la possibilità ad altri di usufruire di queste informazioni in modo facile e veloce.
In questo modo, postando in coda a un messaggio di altro tipo (quindi Off Topic) si crea disordine. Pertanto ti pregherei di fare più attenzione per le prossime volte.
Grazie.
Detto questo...
UnderCoverXP si può rendere portatile.
Istruzioni:
1 - Scaricare X-Launcher da qui link: -Link-
2 - eliminare tutto il codice inserito in X-Launcher_Example.ini e copiare questo:
AppName=UnderCoverXP
[FileToRun]
MainKey=HKEY_CURRENT_USER\Software\Wicked & Wild Inc.
[RunBefore]
[Options]
DeleteTemp=true
MultipleIstances=true
RunWait=true
ShowSplash=false
[SplashScreen]
Image=
Title=
TimeOut=1500
3 - rinominare X-Launcher_Example.ini in X-Launcher.ini
4 - inserire l'applicazione (i files estratti con Universal Extractor o la cartella di installazione) in una cartella chiamata "UnderCoverXP" che va inserita a sua volta in \Bin
5 - lanciare X-Launcher.exe per avviare l'applicazione
6 - da questo momento tutte le impostazioni saranno scritte nella cartella \User
[ Edited Thu 26 Apr 2007 - 14:28 ]
forart.eu
Fri 18 May 2007 - 13:27
Registered Member #4745
RADIOZETA wrote ...
Dunque, ho fatto un po' di search ed effettivamente sw di labeling opn per windows non ce ne sono... pero:
Dialog CD Writer (GPL) di Umberto Galtarossa
CD/DVD Inserts and Envelopes
CDox ma è in Java...
...insomma un sw open decente per stampare CD/DVD e relative copertine.
Sarebbe carino lanciare un progetto per "metterne insieme" uno (un po' alla WinLibre che con la sua partecipazione al SoC ha "creato" infrarecorder)
Al momento si potrebbe pensare di sfruttare questi templates
forart.eu
Sat 19 May 2007 - 13:01
Cerca cerca, alla fine qualcosa viene fuori:
CD Cover di Carlo Beggiato
Sembrerebbe un buon punto di partenza...
Sat 19 May 2007 - 20:17
Ottimo e .... quasi portatile!
Con X-Launcher e questo INI è quasi perfetto (ma non rileva i dati del supporto di masterizzazione):
AppName=cdcover
[FileToRun]
[Environment]
DIR_COVERS=$Home$\$AppName$\Covers\
[Functions]
DirCreate=%DIR_COVERS%
MainKey=HKEY_CURRENT_USER\Software\Cd Cover
Opzioni|"DirCovers"=%DIR_COVERS%|\\"
Opzioni|"Aggiornamenti"="False"
Opzioni|"Warning"="False"
[RunBefore]
[Options]
DeleteTemp=true
RunWait=true
ShowSplash=false
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
[ Edited Sat 19 May 2007 - 20:51 ]
Mon 21 May 2007 - 11:10
a me con questo ini mi ritorna anche il seguente errore:
"error loading MIDAS.DLL"
lo risolvo se metto "midas.dll" nella cartella con x-launcher.
ma non ho capito perchè fa questa chiamata!
Mon 21 May 2007 - 11:17
RISOLTO:
Siccome avevo fatto l'installazione di CDCOVER, quest'ultima aveva scritto 5 voci nel registry che richiamavano la dll con la path originale del programma.
Una volta rimosse "a mano" ho risolto il problema.
Ora verifico se le ha riscritte....
[EDIT BY TAF]
Si, le voci vengono ricreate nel registry!! in questa posizione (e succesive 4 repliche)
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{9E8D2FA1-591C-11D0-BF52-0020AF32BD64}
e fanno capo a:
Borland Midas DSBase 1
[ Edited Mon 21 May 2007 - 11:19 ]
Mon 21 May 2007 - 12:16
Si purtroppo bisogna registrare la dll.. -Link-
Anche esportando le chiavi da te indicate, non si risolve:
AppName=cdcover
[FileToRun]
[Environment]
[Functions]
[WriteToReg=$Home$\$AppName$\$AppName$_1.reg]
[WriteToReg=$Home$\$AppName$\$AppName$_2.reg]
MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\Borland.Midas_DatapacketRead.1
[WriteToReg=$Home$\$AppName$\$AppName$_3.reg]
MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\Borland.Midas_DatapacketWrite.1
[WriteToReg=$Home$\$AppName$\$AppName$_4.reg]
MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\Borland.Midas_DSBase
[WriteToReg=$Home$\$AppName$\$AppName$_5.reg]
MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\Borland.Midas_DSBase.1
MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\Borland.Midas_DSCursor
[WriteToReg=$Home$\$AppName$\$AppName$_6.reg]
MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\Borland.Midas_DSCursor.1
[RunBefore]
RegEdit=$Home$\$AppName$\$AppName$_1.reg;$AppName$_2.reg;$AppName$_3.reg;$AppName$_4.reg;$AppName$_5.reg;$AppName$_6.reg
[Options]
DeleteTemp=true
RunWait=true
ShowSplash=false
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
[ Edited Mon 21 May 2007 - 12:18 ]
