[data mining] X-weka
bagr
Sun 20 May 2007 - 10:46
Registered Member #4759
Software name: X-Weka launcher
Direct Link to download: -Link-
Description:Weka is a collection of machine learning algorithms for data mining tasks. The algorithms can either be applied directly to a dataset or called from your own Java code. Weka contains tools for data pre-processing, classification, regression, clustering, association rules, and visualization. It is also well-suited for developing new machine learning schemes.
Version: 0.1 alpha
Portable tips how-to:
Download Weka extract with uniExtract copy all files from weka-3-5-5 except [NSIS].nsi and weka-3-5-5/$_OUTDIR to X-Weka/bin/Weka. Install Java on your computer and copy the installation folder to the Lib\Java folder.
License: GNU
1179650771_4759_FT0_x-weka-launcher.rar
Sun 20 May 2007 - 11:01
I have not RunWeka.bat in my application folder after the UE extraction ..
[ Edited Sun 20 May 2007 - 11:01 ]
bagr
Sun 20 May 2007 - 11:19
Runweka.bat is in folder weka-3-5-5/$_OUTDIR. All files in weka-3-5-5/$_OUTDIR put in to X-Weka/bin/Weka
Sun 20 May 2007 - 12:12
Yes! It works fine
But, where the application saves user settings?
In \Bin\Weka\data folder?
[ Edited Sun 20 May 2007 - 12:12 ]
bagr
Sun 20 May 2007 - 15:41
Application doesn't save users setting or i didn't find it.
All settings are in RunWeka.ini
===X-Weka.ini======================
AppName=Weka
[FileToRun]
PathToExe=$Bin$\$AppName$\RunWeka.bat
[Environment]
PATH=$Lib$\Java\bin
JRE_LIB=$Lib$\Java\lib
JAVAW=$Lib$\Java\bin\javaw
[Options]
DeleteTemp=true
RunWait=false
ShowSplash=true
[SplashScreen]
Image=
Title=
TimeOut=1500
