Skype 3.0 Go to page << >> |
Microchip |
Registered Member #4763 Joined: Sat 19 May 2007 - 18:48Posts: 63 | ho visto tanto thread su Skype portabile, in alcuni si parla del launcher x-skype e di test vari sull'applicazione. Come mai non se ne sa più nulla? Ci sono novità? grazie | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Non uso skype. Posta un log di regshot e vedo di fare un launcher. | ||
bagr |
Registered Member #4759 Joined: Sat 19 May 2007 - 09:25Posts: 15 | This is a regshot of Skype 3.2 skype3.2-registry.rar [ Edited Sun 20 May 2007 - 19:23 ] | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | Thank you bagr for your support Ini for Skype, (but I have not tried it). Please, let me know, if you want, if it works.
[ Edited Fri 25 May 2007 - 09:58 ] | ||
bagr |
Registered Member #4759 Joined: Sat 19 May 2007 - 09:25Posts: 15 | @Danix I tested sky.ini but there is still the same value in registry. Take a look in regshot file 1179933489_4759_FT164_skype.rar | ||
Registered Member #1 Joined: Fri 29 Dec 2006 - 05:38Location: Sassari Posts: 12956 | They are not the same values... But the software is portable? It saves settings in \User folder? | ||
bagr |
Registered Member #4759 Joined: Sat 19 May 2007 - 09:25Posts: 15 | U are right Danix. What bothered me was a entry in registery HCU/Softwer/Skype but that was just temporarily (when Skype was on). But the software is portable? Yes, i think so. I didn't find any problems. The .ini file was tested on skype 3.2.0.148 [ Edited Thu 24 May 2007 - 21:06 ] | ||
UncleDan |
Registered Member #4764 Joined: Sat 19 May 2007 - 19:39Location: Bologna, Italy Posts: 125 | Posso chiedere dove trovo X-Skype.exe che non vedo nella sezione X-Launchers? --- May I ask where I find X-Skype.exe, which I don't see in the X-Launchers section? | ||
Registered Member #74 Joined: Sun 21 Jan 2007 - 11:31Location: Tradate (VA) Posts: 3821 | Ciao UncleDan, X-Skype, come tale, è stato rimosso fino a quando non avremo l'autorizzazione a distribuire il pacchetto con l'X-Launcher. L'unico modo è di usare X-Skype.ini che trovi qualche post sopra di questo, fatto da Danix (e testato da bagr) in congiunzione con X-Launcher (che trovi qui -Link- ). Ci sono due modi per eseguirlo: 1) Edita X-Launcher.ini ed inserisci quanto fatto da Danix (da [Setup] fino a Timeout=1500, compresi), poi esegui X-Launcher.exe 2) Crea il file X-Skype.ini ed inserisci quanto fatto da Danix. Esegui poi X-Launcher.exe con l'opzione --x-launcher-config=X-Skype.ini Cordialmente ZioZione P.S. Non c'è bisogno che scrivi anche in inglese... | ||
Registered Member #251 Joined: Mon 22 Jan 2007 - 10:12Location: Buttrio (UD) Posts: 3358 | Sto ancora aspettando un feedback da Skype..... mi sembra un'impresa abbastanza ardua! Alla prima mail mi hanno risposto con un testo "preconfezionato" che non diceva nulla in merito alla possibilità di pubblicare un X-Launcher dedicato. Il secondo feedback non è ancora arrivato! Eventualmente proverò con un altro canale mail... @Ziozione: probabilmente Uncledan aveva scritto anche in inglese perchè Bagr scrive in inglese.... | ||
