X-MediaPlayerClassic launcher
Sun 03 Jun 2007 - 17:30
Grazie alla segnalazione di bagr mi sono accorto che Media Player Classic salva la
Playlist in %APPDATA%.
Versione portatile da testare, sperando che non siano solo gli stranieri a testarla oltre che a segnalare i bugs - scusate la doverosa frecciatina -
Thank you bagr!
X-Launcher Ini for test:
(inserire il player in una cartella chiamata "Media Player Classic")
AppName=Media Player Classic
[FileToRun]
PathToExe=$Bin$\$AppName$\mplayerc.exe
[Environment]
SNAP_SHOT_PATH=$Home$\$AppName$\Images\
[Functions]
DirCreate=%SNAP_SHOT_PATH%
DirMove=$Home$\$AppName$|@AppDataDir@\$AppName$|o
[RunAfter]
DirMove=@AppDataDir@\$AppName$|$Home$\$AppName$|o
[WriteToReg=$Home$\$AppName$_registry\mplayerc.reg]
MainKey=HKEY_CURRENT_USER\Software\Gabest
Media Player Classic\Settings|"SnapShotPath"=%SNAP_SHOT_PATH%|\\"
[RunBefore]
RegEdit=$Home$\$AppName$_registry\mplayerc.reg
[Options]
DeleteTemp=true
MultipleIstances=true
RunWait=true
ShowSplash=false
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
[ Edited Fri 23 May 2008 - 23:32 ]
Sun 03 Jun 2007 - 17:39
@bagr:
look for the "SnapShotPath"
But, can Media Player Classic save snapshot??
How?
bagr
Sun 03 Jun 2007 - 18:07
Registered Member #4759
Thank you Danix that you made *.ini file so quick.
I think that MPC can save snapshot (Images)
Play some video file (File -> Save Image... / Save Thumbnails...)
MPC can even record ( Open device (TV tuner) and then View -> Capture)
I tested .ini file and didn't find any problems.
Sun 03 Jun 2007 - 18:14
Registered Member #9
@bagr:
How?
I haven't tested it but I think you should use one of these File menu options: File - Save Image... or File - Save Thumbnails...
Just try.
Sun 03 Jun 2007 - 18:15
There is a bug... I'll correct this....
Sun 03 Jun 2007 - 18:24
Ok!
Now the program saves thumbnails in the "default" folder.
Sorry but I can't create only one folder for settings, but three...
I'm going to try it..
[FileToRun]
[Environment]
SNAP_SHOT_PATH=$Home$\$AppName$_Thumbnails
[Functions]
[RunAfter]
[RunBefore]
[Options]
DeleteTemp=true
RunWait=true
ShowSplash=false
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
[ Edited Sun 03 Jun 2007 - 18:27 ]
Sun 03 Jun 2007 - 18:49
This is the last INI.
Now, ONLY ONE Media Player Classic folder FOR settings is created:
(please, test it )
[FileToRun]
[Environment]
SNAP_SHOT_PATH=$Home$\$AppName$\Thumbnails
[Functions]
FileMove=$Home$\$AppName$\default.mpcpl|@AppDataDir@\$AppName$\default.mpcpl|o
[RunAfter]
FileMove=@AppDataDir@\$AppName$\default.mpcpl|$Home$\$AppName$|o
DirRemove=@AppDataDir@\$AppName$
[WriteToReg=$Home$\$AppName$\mplayerc.reg]
[RunBefore]
RegEdit=$Home$\$AppName$\mplayerc.reg
[Options]
DeleteTemp=true
RunWait=true
ShowSplash=false
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
[ Edited Sun 03 Jun 2007 - 18:50 ]
Tue 31 Jul 2007 - 01:52
Media Player Classic [rev2]
Alcune chiavi di registro in HKEY_LOCAL_MACHINE mi sono sfuggite...
Inoltre, dato che il programma offre la possibilità di salvare le opzioni in un file INI all'interno della propria cartella, bisogna prevedere il percorso per i thumbnails anche in questo caso:
INI:
[FileToRun]
[Environment]
[Functions]
FileCopy=$Home$\$AppName$\mplayerc.ini|$ExeDir$\mplayerc.ini|o
[RunAfter]
FileCopy=$ExeDir$\mplayerc.ini|$Home$\$AppName$\mplayerc.ini|o
[WriteToIni=$ExeDir$\mplayerc.ini]
;        ** Italian version **
Impostazioni|SnapShotPath=%SNAP_SHOT_PATH%
;        ** English version **
;Settings|SnapShotPath=%SNAP_SHOT_PATH%
[WriteToReg=$Home$\$AppName$\mplayerc_1.reg]
[WriteToReg=$Home$\$AppName$\mplayerc_2.reg]
MainKey=HKEY_LOCAL_MACHINE\SOFTWARE\Gabest
[RunBefore]
RegEdit=$Home$\$AppName$\mplayerc_1.reg;mplayerc_2.reg
[Options]
DeleteTemp=true
RunWait=true
ShowSplash=true
WriteLog=false
[SplashScreen]
Image=
Title=
TimeOut=1500
Attenzione: notare la parte seguente (già impostata per la versione italiana)
Da impostare a seconda che si utilizzi la versione italiana o inglese del software.
[ Edited Tue 31 Jul 2007 - 01:58 ]
Tue 31 Jul 2007 - 08:30
il mio test con questo ultimo INI mi dice:
ERROR: ....lamiapathdiwpp/bin/MyApp/.... NOT FOUND!
perchè vuole che la cartella "Media Player Classic" sia "MyApp"??
se cerco nell'ini... tale sintassi non la trovo...
(sarò utOnto...ma è così! )
[ Edited Tue 31 Jul 2007 - 08:32 ]
Tue 31 Jul 2007 - 09:43
COME NON DETTO!
il problema mi si presenta SOLO se COPIO/INCOLLO l'ini qui presente.
Ho scaricato la versione "ufficiale" da qui:
e tutto è tornato a posto...
comunque sarei curioso di sapere il perchè...
[ Edited Tue 31 Jul 2007 - 09:43 ]
